the biggest alternator for ml 430 year 2000
Old Oct 7, 2010 | 01:31 PM
thecat666's Avatar
MERC ML430 YEAR 2000
can any body help me? i am running quite a big system in my merc ml 430 year 2000 it comes standard with 150 amp bosch alternator. my question is what is the biggest alt that i can bolt straight on without having to get a bracket or brackets made up. all help thanked in advance.
Old Oct 7, 2010 | 06:53 PM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
The 150 amp should power most anything you can put into the ML.
Old Oct 7, 2010 | 07:28 PM
mihir_d's Avatar
2000 ML320 2006 SLK 350
Agree 100%
That's a 100Amp battery mated to a 150Amp alternator..What more can you ask for?
If you insist, you can mate a 1500Amp alternator to the ML as well...all you need to worry about is the mounting...and you can always build a custom mount for any alternator...
You will lose some hp on the wheels by mating larger alternators..
Old Oct 8, 2010 | 07:33 AM
thecat666's Avatar
im running around 4200 rms just on subs i have 2 big yellow batterys 100 amps each batt their weight is 43-47 kilo's each one
Old Oct 9, 2010 | 08:09 AM
benzml350's Avatar
2003 ML 350
http://www.zena.net/htdocs/alternators/alt_inf5.shtml
You need a large external rectifier for that unit and I'd certainly keep it isolated from the Benz electrical system. If you can stuff that big boy under the hood and devise a pulley to drive it you should be able to inflict pain continuously instead of the half hour of reserve power you have in your batteries.
