2001 ML430 CLEAR CHECK ENGINE LIGHT & OVERDUE SERVICE MILES
Old Oct 20, 2010 | 01:16 AM
Racerx18691's Avatar
Mercedes ML430
My check engine light comes on sometimes. It has been on for awhile lately. Is this because the mileage indicator says I am overdue for service? How can I clear that? I had the service done been not at a dealer. The dealer was too expensive. Also, I have had "fluttering" acceleration right after I changed the battery. Never had that problem before I changed the battery and the CPS. Is that normal? Also, it was idling rough when I was at a stop light for awhile but went away. The car wanted to accelerate with the brake on, even though the idle was normal. Does this happen after you have it serviced to the let the computer reset? Thank you for your help!
Lance
Old Oct 20, 2010 | 04:41 PM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Check engine light is not on because the service light is on. Your problems are for the most part due to your poor decision and your trying to save a nickle by having work done by someone who has no clue. You got what you paid for!! Now just take it to the dealers and get it done correctly and its going to cost you.
Old Oct 21, 2010 | 12:20 AM
Mercedes ML430
the part that was replaced was easy. anyone can do it but I did not have a life. it only cost $40 for the part online and $100 to install. the dealer wanted $600 for the part and install. why would I waste that money when a monkey could install the part and a battery?
Old Oct 21, 2010 | 01:01 AM
Mercedes ML430
sosh can you please tell me what a PO 170 and PO 173 code is for a 2001 ML430?
thanks sosh
Lance
Old Oct 21, 2010 | 08:27 AM
sosh's Avatar
The only problem is that you car is still not fixed and has numerous issues. I guess the monkey that changed the CPS could not do the rest of the job. Sorry I can't help you with the codes but someone else may jump in here.
Old Nov 1, 2010 | 10:35 PM
PaulX608's Avatar
2011 VW cc, 2004 ML350
thanks sosh
Lance
They're fuel trim codes, usually indicating a MAF that needs replacing. Easy job, and will greatly improve throttle response, driveability, and fuel mileage.
