How do I remove engine cover and can I change my own spark plugs?
Thank you,
Lance
You get 16 sparl plugs bosch 7422 at any good auto supply store
A torx bit set a special 17 mm boot tool that makes it easy to pop off the metal spark plug boots a 5/8 in spark socket a few short extensions a small u joint socket adapter then follow the diy posted on www.benzworld.org in the w210 diy section same procedure for that engine which is the same M113 as your engine.
Takes a few hours for even a beginner and plugs tools and all about 120 bucks less if you have a tool box with the simple stuff already vs dealer up to $800 or more
I pulled an old plug out and it says Bosch F8DPER. is that possibly
the original factory spark plug? It doesn't say Mercedes on the plug.
The new plugs are Bosch 7422 double platinum.
I measured the gap and the new plug is 39.
Is that what I need?
I'm changing out all the wires also.
ML430 has 100K miles.
