trans leak
Old Nov 9, 2010 | 11:49 AM
ml350's Avatar
2005 ML 350
trans leak
Hi,
did anybody have their trans leak on their ml before,
Old Nov 9, 2010 | 01:53 PM
Driver55er's Avatar
w210 e55
I had a leak on my trans cooler line. The line got loose at the fitting that goes to the trans. You can see it underneath. 200 dealer part for hoses or 140 aftermarket. Also common problem is the o rings at the electrical connector 15 dollar fix. Do a search you will find a diy for the electrical connector
http://www.rmeuropean.com/Part-Numbe..._5C1313F8.aspx
