Parking lights and auto lights not working ?
Old Jan 11, 2011 | 01:26 PM
Northern lights's Avatar
ML270 cdi
Smile Parking lights and auto lights not working ?
Hi, can anyone help me out with my lights ? my ML270cdi 2002 has had lights set on auto for several months no problems, turned them off the other night now they won't work on auto or parking, everything else working fine, any ideas ? thanks
Old Jan 20, 2011 | 10:56 AM
dewdaltz's Avatar
02ML320/06R350
check the fuses...open the hood on your right next to the fender with black cover open that up.
Old Jan 21, 2011 | 02:53 PM
ML270 cdi
Hi, thanks for that, have checked fuse box under bonnet and the one in the footwell, all okay !!!
Old Jan 28, 2011 | 11:01 AM
jsjimen9's Avatar
ML320
Could be a fault on Relay K6..Try to jump the pins for those lights and see if it works.
Old Jan 8, 2012 | 01:03 PM
alphonsohall's Avatar
ML270CDI
I have EXACTLY the same problem......i've tried everything to get them to work again without success........did you find the cause?............anyone?
Old Jan 9, 2012 | 11:46 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
The way these parking lights work is as follow. The left and right sides are operated from the Combination Switch to the relays to the fuse and then to the lights. The left and right side have individual relays and fuses.
Working with the left side parking lights, remove the K13 relay. Fashion a small piece of elec. wire stripped at both ends. With the key in the on and the combo. switch turned to parking lights, ,stick one end of the wire into slot #30 at the fuse box and test for battery voltage at the other end of the wire with a test light or DVOM. Then do the same for slot #86.
Attached Thumbnails Parking lights and auto lights not working ?-2012-01-09_100717.jpg
