PLEASE HELP
Old Jan 25, 2011 | 06:42 PM
Dblock55's Avatar
ML320
PLEASE HELP
My 2002 ML320 died on me while i was driving home from work today... the car was going 30 when it just shut off!!! I pulled over and turned it back on and the battery indicator was on... i pushed the gas and the car immediately stalled... i checked the battery and alternator pulley and all seemed well... i reset the battery and then a check engine light went on... i had to put the car in drive and let the car idle home..... if you depres the gas pedal any amount the car will immediately stall.. also on random the check engine light will come on and also the airbag off indicator will come on and turn off as well as the battery indicator.. does anyone know WTF is going on??
Old Jan 25, 2011 | 07:10 PM
Dblock55's Avatar
ML320
update... when in park, i press the gas and the gauges fall to 0 for a second and then jump back up... so im thinking a wire is shorting out somewhere.. anyone know what i should be looking for??
Old Jan 25, 2011 | 09:49 PM
PaulX608's Avatar
2011 VW cc, 2004 ML350
It's the alternator. Our '04 did this to my wife last Halloween. Absolutely did exactly the same thing as you describe.
Old Jan 25, 2011 | 10:31 PM
Dblock55's Avatar
ML320
Was digging around and that's what I was thinking... tgx so much for d help!!! Thank god I was drivingbabd not d wifey, she woulda crashed the thing cuz the power steeringband brakes went out due to engine cut off... mercedes should have made a system where d car deceleratss first then stalls...my old cheap mitsubishi had that...
Old Jan 26, 2011 | 06:43 AM
vinnie1068's Avatar
ML 500
Happened to me too it is The ALTERNATOR definitely, exactly the same as you describe it!
Old Feb 11, 2011 | 07:52 PM
c3212571's Avatar
2002 Mercedes c32 1998 Toyota tacoma 2002 Honda Cbr600f4i
Usually all mercedes with valeo alternator's regulator go bad not the whole alternator. See if you can just purchase a bosch brand regulator. !!!!!!!!!!!always change your tranny fluid!!!!!!!!!!!! On ML's!!!!!!!!!!
