Guys, I need some help!!
The one you are talking usually happens when you drive in snow and the car get so slippery(that's when the ESP kicks in). I will bring them to the shop and ask them to take a look.
That just means that your car is in a hazard mode cuz u're working your car too much....did you like slam on your brakes or something?? i usually get that warning when i'm making a fast sharp turn...and it warns you dat u should slow down, and if u go faster, your car might flip or something....
Sorry but that's very amusing
.I believe you're referring to when the triangle flashes - that's when ESP (electronic stability program) kicks in - not some 'hazard mode' BTW.
As for the original problem, I would recommend to have the dealer check out the situation. The light will remain on if the car's put into Low Range, but that would drastically alter the driving (goes no more than 30-40mph) feel so you would notice it if that was the issue. Probably with the brakes or an internal problem of some kind - have the stealership (o I mean dealership) check out it.
that would be below the fuel guage. the ESP light is shaped like a triangle? thats in the middle of the speedo. turn the key to position 1 and see if you can indentify the light that was on.
