door lock rear will not lock,
Old Mar 22, 2011 | 02:58 PM
halglfn's Avatar
1999 Mercedes ml430
right rear door lock will not engage, when the remote is used the right rear lock does not lock. when you start to drive and lock tries to lock it does not.
Old Mar 31, 2011 | 10:52 PM
Stiggs's Avatar
2003 CLK55
Does it rapidly move up and down multiple times?
My passenger side lock did that. Needed to replace the door lock actuator. Cost over $400
Old Dec 9, 2011 | 10:46 PM
HEEMS's Avatar
2002 ml55
im having the same problem with my 2 rear doors they sound like machine guns lol. did u change then yourself? if so how big of a job and what steps did u take?
Old Dec 10, 2011 | 07:45 PM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Here are the instructions. You should also make sure you have the proper tool to remove the door panel clips to prevent them from breaking.
File Type: pdf
File Type: pdf
File Type: pdf
