MCS Screen Message - No Data
Old Mar 24, 2011 | 11:48 PM
gambari's Avatar
05 E55, 08 S63, 09 GL450
Need some help/advice...
I just bought the wife a 2003 ML350 and in the process of reviewing settings, I get this error message on the MCS display whenever I push the "SVC" or service button. I also hit the "update" button but it fails to connect.
Has anyone got an idea what i must do to correct this? Thanks!
Old Jun 25, 2014 | 06:59 PM
waybomb's Avatar
SL600 r230, SL600 r129, SL500 r230, ML320, C280 Sport, R170 450SL, 190e 2.3 16V (2)
TTT - I know it's an old thread, but maybe somebody could please take a few moments and reply...
I also just bought a 2003 ML350.
I did a search for SVC and am more confused now then before.
The datacard on Startek EPC indicates these three items that may be relevant to my questions:
522 radio ICU "Alipine" USA
810 Sound System
819 CD Changer
If I go into the parts explosions, The 333 subsection CNS is all greyed out, so that was not standard
If I go to section 315 radio, part 7 shows CDC and mentions a red highlited note that says "for command" and a bunch of other stuff. part 6 is a smaler radio, but that part is greyed out.
What do I have - MCS or Command? Maybe installed later - if so, how can I determine what it is? The screen says MCS, but post repliers say MCS did not come out until later models. How do I know if I have MCS or COMMAND? Are they the same thing?
The SVC function does not work. How do I enable it? What does it do?
Also, the 1 dvd that came with it is scratched beyond being readable.
I did some searched and now the DVDs are in regions. But maybe I need CDs?
Will the newer ones work in a 2003 Nav system?
What version should I buy? I need to cover all of Wisconsin, Illinois, Indiana, Michigan, Ohio, and on down to West Palm Beach.
Thanks!
Old Jun 26, 2014 | 05:26 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
It appears that you only have a standard MCS, no command, which is Navigation.
Press the OPEN button at the upper right corner and the screen will flip down. If there is no place to insert a CD, you do not have NAV. Press OPEN again to close the screen.
Old Jun 26, 2014 | 09:49 PM
waybomb's Avatar
There is a DVD slot.
The dvd is really scratched up.
If I insert it and turn on Nav, it indicates it has nav but has an error reading the dvd.
Somebody suggested sending the DVD to a refurbisher, so I am going to give it a try. Its only 5 bucks.
Old Jul 14, 2014 | 01:51 PM
waybomb's Avatar
Got the Nav dvd resurfaced. Slid it in. Color Nav comes up and works great. Drove to Toledo this weekend and back using it.
But SVC still comes up not available.
What is the SVC for, and how do I get enabled?
