Catalytic converter ?
Old Apr 20, 2011 | 10:48 PM
LMA1973's Avatar
1999 ML430
Just yesterday my ML430 started having a fluttering/air sound coming from under the vehicle and a slightly noticeable loss of power. It sounds like its coming from one of the cats. Anyway, if its a crack in one of them would you guys have it welded or would you just go with the Magnaflow cats (its only like 80 bucks a peice) and just go ahead and get 2 of them and replace both?
Old Apr 21, 2011 | 12:03 AM
Darkmann's Avatar
ML
You may want to do some more research (I guess that's what you're doing now!). Don't know about the 430, but don't these trucks have a set of F/R cats? As I recall, the Magnaflow units are for the rear cats only. Check to make sure which cats are bad first. I need this info also!
Old Apr 21, 2011 | 09:27 AM
LMA1973's Avatar
1999 ML430
Im going to take it to the exhaust shop tonight or tomorrow. I'll keep you posted as to what i find. Yeah it does look like this thing has 2 cats per side. The Magnaflow only replaces one of the cats. Autopartswharehouse.com sells the complete assembly with both cats for a little over 400 bucks. Lets see what the exhaust shop can do first!
Old Apr 21, 2011 | 01:38 PM
benzeboy's Avatar
ml320 & c240
I beleave there was a recall on the ml for cat. problems.
Not sure about the ml 430. I have a ml320 year 2000 and the dealer replaced the cats. under the recall.
Old Apr 26, 2011 | 09:45 AM
LMA1973's Avatar
1999 ML430
Okay-i just got a call from my muffler shop. Both the driver and passenger side cats are cracked but he is able to weld both and is charging me $125. I said go for it!
Old Aug 13, 2011 | 02:45 PM
AlbaBenzer's Avatar
2001 ML 320
benzeboy..You mentioned you had yours replaced under a recall..if im not wrong that recall was a few years back..im having problems with my cats too..i dont think i would be able to pull up to a dealership and have them fix it a few years after the recall?..correct?..thanks =)
