Relay and fuses next to cabin air filter ML 270 CDI 2003
I am new to this forum and I have searched the internet for answers without any luck.
When I changed the cabin air filter, I discovered 1 burned relay next to the cabin air filter. I have not discovered any thing that does not work on the car so I do not know what this relay is for. There is total 3 relay in a row any they are marked A002 542 26 19. There is also 2 fuses next to the relay which are 30A and 60A. Can anyone tell me what these 3 relay and 2 fuses are fore?
Anyone how know the answers? (The local dealer did not know)
(on the attached picture there is only 2 of 3 relay showing)
Link is for reference......
http://www.justanswer.com/mercedes/4...el-heater.html
The fuse/relay box you refare to in the attachment is located at the right side of the passanger side. In my car I also have this fuse box. The 3 relay I refare to is located under the cover for cabin air filter.
I understand from the link that the heater booster dos not have external relays:
"Diagnostics Engineer :
Electrical heater booster must have constant positive supply and 2 communication lines to ECU. The controls are integrated into heating unit- so there are no external relays to check."
I have checked more and found the cables are marked:
1 cable attached to fuse holder: #6805-F24/5-2->K16/2-2
1 cable attached to relay holder: #6802-K16/1-8......
Maybe this can help someone to tell me what these relays are used for?
Of course, you could just buy a new relay!!
No idea the price. Don't be tempted to swap it for one of the other relays as they all seemed to go on and off as I was changing the temp control knob.Hope this helps!
Thanks.
Hope this helps
Once again I found the relay melted.
As fare as I can see there may be 2 resonce for this:
Option 1:
The amp on the relay is too small. I wonder what is the Amp on this relay? Can you please check on your car? MB part no. A 0025422619. There are 2 fuses marked 60A and 30A just below these 3 relay, maybe the 60A fuse have something to do with the booster heater? I think the relay must be 60A aswell.
Option 2:
I can see some residue of liquid from the AC unit. The liquid may have shorted the relay. I have put a waterproof "roof" above the relay to prevent this to happen again.
I need the get a new relay and a relay socket.
When I was listening to the relays as the car warmed up I noticed the other relays were switching on and off. It could be that your other two relays are at fault and are not switching when they should. If you are thinking of changing the relay again, I suggest you keep a finger on it while switching the engine on with the heater dial at max COLD which means that the relay should not switch on. Then turn it until there is a click and the relay should warm up. My relay got warmer than I expected.
Also, the fuses I have are the same as yours... BIG! Never seen car fuses that big.
Sorry I could not be of much help.
Rick
I have search the net and found that this standard relay used by MB is 40A. If the current is to high for this relay a will change it to a bigger one. I have also ordered a ny relay socket. I am suprised that MB are using this standard relay all over the car. If you look at the power cord on this 3 relay under the glovbox it is the aft one which have the bigges cord (highest current).
Thanks for your replay.
Regards
M
