2000 ML320 9 Codes shows up
Old 03-05-2012, 08:28 PM
alex5357aa's Avatar
2000 Mercedes ML320
Hi to everyone.2 days ago i bought my mercedes ml320.I bought it with the check engine lights is on and it was showing thats its need a crankshaft position sensor.I replaced today.And after i replaced its still showing up....and another 9 codes codes like o0150 , p0170 , p0173 , multiple misfires , misfire in cylinder 3,5,6,7 ) .I'm thinking its a ECU,but my mechanic said that i need to drive it for couple days.The thing is that when i had only p0335 code ( crankshaft position sensor ) it was stalling and then after some times start again.but i never had expirienced misfire.No its driving and start right away.And only starting misfiring when im pressing the gas hard and transmission shifts to lower gears.When its happing i'm just turn it off and start it again and it will drives fine if im not pressing the gas hard.Please guys help with some advice.Thank you
Quick Reply: 2000 ML320 9 Codes shows up
