2000 ML55 ABS FAULT??
Old Mar 13, 2012 | 06:36 PM
aasim305's Avatar
2003 s430
Question 2000 ML55 ABS FAULT??
Hello
I have a 2000 ml55 my cluster stopped working and i have ABS ETC BAS lights on anyone know what can this problem be? i was told it could be may ABS pump causing this issue???
Old Mar 13, 2012 | 08:53 PM
hba's Avatar
hba
check under the windshield wiper reservoir....
for leaks, if so $$.
check if some one can read out the code with an obdII connection and check for 'lateral acceleration sensor' (+/- $120,-) or 'yaw rate sensor'(+/- $590,-) either sensor you can replace your self, and safe some $$ on the dealer visit.
hope any of the above helps you out.
best, herman
oops and check at he dealer if your open recall brake pedal switch is already 'switched'
Old Mar 14, 2012 | 11:35 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Originally Posted by aasim305
Hello
What do you mean by your cluster stopped working? If you have ABS, ETS & BAS lights on that doesn't mean the cluster is not working.
