misfire and powerloss w/code p0131 and p0456
Replace the upstream O2 sensor on that side.
The cause of code P0456 could be the sealing of the gas cap. Remove it and inspect the O-ring for cracks. If so replace the gas cap. If the cap is OK then you will have to have a Smoke Test performed by a mechanic on the Evap. System.
You say that you have multiple misfires but only list P0302. Do you mean Random Misfires (P0300)?
Also, code P0171 (which should be P0170. There is no P0171 for M/B) is probably being set because of the bad O2 sensor.
Get these things done and then see if code P0302 still remains. If so then you will have to start switching spark plugs from #2 cyl. to another one, then check for misfire on what cyl. If it still remains, then switch the ign. wire to another cyl. and check for misfires.
Please update your profile by adding the year and model ML.
Glad you solved your problem..
I bought a 1998 ml230 2 years ago.It runs great until 3 months ago.The problem started with hesitations upon initially stepping on the gas every time you shift gears(manual transmission)but ones you got going,it runs fine.Now even the idling gets rough intermitently and if you step on the gas it backfires then dies on you.The problem intensifies when uphill but turning off the Aircon helps.Ive replaced the airmass,sparkplugs,fuel filter even tried on a new throttle valve with no success.I took it to the mercedes dealer but the dealer said it shows no error codes because the All Activity module(AAM)does not match the trucks actual VIN No. so it doesnt effectively communicate with their diagnosis equipment.They advised me to change the AAM so it may work with their equipment, then they might be able to tell me whats wrong.The AAM is too expensive and as I found out,the AAM is not the control module for the engine. I will appreciate any help or suggestions.Help Please!!thank you in advance.
Regards,
Jericho
Regards,
Jericho
As usual, M/B dealers stike again. The AAM, which stands for All Activities Module, is another name for Body Control Module. It controls wipers, lights, signals, horn, locking system, etc. but has nothing whatsoever to do with the running of the vehicle.
Problems going uphill and backfiring is a classic example of a clogged catalytic converter. You don't say what misfire codes you have but if they are cyl. 1,2,3 then it is the pass side; 4,5,6 is the driver's side.
The hesitations and backfiring does not only happen when uphills..it happens on every initial accelerations after shifting gears.I have to find out what misfire codes i have..Ill let you know soon.But what could be causing it??Thank you so much..
Why in the world did you drill a hole in the exhaust pipe? The correct thing that should have been done is remove the upstream O2 sensor on the suspected side and take a test drive.
If you don't remember the misfire codes, how did you know what side to drill a hole in? As a matter of fact, what side did you drill a hole on?
Ive been doing some research and it seem the symptoms are either from ECM or camshaft position sensor.My truck is only a 4 cylinder engine(ml230) manual transmission.Your ideas will be much appreciated.Thank you.
Can this be a leak in the exhaust? Cat converter need to be changed? Vacuum Leak? Or fuel filter? This is a major headache! HELP!
In any event, PLEASE UPDATE YOUR PROFILE in USER CP to include where you live.
Code P0456 is for a small leak in the Evaporative System and has nothing to do with changing an O2 Sensor and clearing code P0456.
