looking for straight answer - wheel offset required on AMG
What offset does the standard ML series have (04) and what offset does the ML500 Sport have ? Am I also to assume that would be the same as a ML55 ? With this information, I can make sure I am getting the correct thickness spacers.
Unless somebody already has done this and knows what is needed.
The wheels I bought are 20x8.5 with 48mm offset.
Math is not my strong suit, but I think you need close to a 10-12mm spacer which is only about 1/2 inch to get the same effective offset with 8.5 inch wheels.
Your 8.5 inch wheel has 1/2 inch less on each side of the centerline. So in theory, your wheel needs about 12.5mm (about 1/2inch) less offset than a 9.5 inch wheel to keep the centerline in the same place. Then 52-12.5= 39.5. You have 48, or about 9mm too much offset.
Anyone else reading this, feel free to check/correct my math.
Spacers by themselves are no big deal, either get longer bolts or better yet, switch to studs. Much easier to hang a wheel.
But if you have a brake clearance issue because of wheel design, you will need to push the wheel farther out so it no longer contacts the brake caliper. That will require you to measure. I would take a SWAG that 20mm spacers would work, but just a SWAG.
Regards,
Jerry
