2000 ML320 Electrical issues
Old Aug 6, 2012 | 09:39 AM
jzito's Avatar
ML320
I have a 2000 ML320. We had just filled up & started the car, Just as I went to put it in gear it died, the only thing that seems to work is the radio and the readouts on the dash. everything else is not working. Even went thru the entire fuse box and no blown fuses. I can’t even get the OBD reader to read. Had the battery & the alternator tested and there both fine. I have power all the way too the fuse box but that seems to be it. Any ideas??
Old Aug 8, 2012 | 05:04 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Does the eng. crank when you turn the key?
