03 ml 320 radio issue
Old Sep 28, 2012 | 09:45 PM
Hugs's Avatar
2003 ML 320
So I've been researching online for this and having no luck, figure a place like this would a good solution.
My FM radio does not seem to work. I can only hear it if I turn the volume up close to the max, but even then it is soft and there is static and a high pitch sound.
My AM is almost the same except the sound is a bit louder, but just passing a small tunnel, large concrete structures would cause static.
It was completely fine no static or low volume one day, the next morning these issues.
Thanks in advance for any input.
Old Sep 29, 2012 | 06:03 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
All your problems emanate from the tailgate where the antennas, splitters, etc. are. It is not the radio so don't waste your time.
Attached Thumbnails 03 ml 320 radio issue-2012-09-29_055841.jpg   03 ml 320 radio issue-2012-09-29_055925.jpg
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Sep 29, 2012 | 06:04 AM
Also check fo a broken coax cable at the flex point of the tailgate.
Old Nov 6, 2012 | 04:55 PM
Hugs's Avatar
2003 ML 320
Thanks for the input =D I still haven't found out what the issue is tho. I've opened the tail light area and checked all the cables, none of which are disconnected. Is there a fuse that may have broken? I realize that my tail light had gone out, and I've replaced it, is there a connection between the two the may have caused my issue? Thanks again for any input.
