Tow Hitch
Old Aug 8, 2003 | 06:22 PM
Max (SD)'s Avatar
996 Turbo, ML320
Tow Hitch
Just installed the MB Tow Hitch on our ML320. Pretty straight forward.
When I turned on the car, the BAS/ESP light stayed on. Did I do something or is this just a coincidence. I did unhook the negative lead to the battery and re-hooked after installation.
Any thoughts?
Old Aug 18, 2003 | 02:36 PM
mb_gopher's Avatar
be carefull with the wiring connector that plugs into the receptacle on the vehicle itself. on mine the contacts got pushed back inside the connector body and failed to mate ==> no trailer lights!
make sure you check these every so often to make sure you have trailer lights!
