2001 ML430 sunroof will not close please help.
Old May 9, 2013 | 08:34 AM
Racerx18691's Avatar
Mercedes ML430
The sunroof will open but not close. I was told that it could be the plastic clips but I was not told what the plastic clips looked like or how to replace them. I am not sure where they are located. Please help. Thank you.
Old May 9, 2013 | 07:09 PM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
What do you mean by "it won't close"? It doesn't move at all or it only closes partially?
Old May 10, 2013 | 02:43 AM
Mercedes ML430
it closes most of the way but then stops. I know the motor is working. do you know what it might be? thanks.
Old May 10, 2013 | 04:09 AM
Have you made any effort to look? There might be debris/object on either side of the glass track?
Or if the battery voltage dropped below 10v or you disconnected the battery, you will have to resync the system.
File Type: pdf
