Transmission Fluid is brown (I took photos of it)
I placed the sampled fluid onto a facial tissue. Shouldn't it be red in color?
I inserted a clean flexible cable into the "MB workshop only" dipstick tube. I wanted to see the quality of the ATF and I am not pleased.
The shift quality feels OK, nothing apparently wrong. Sometimes it will stay in a gear for an extended period of time, but nothing too outrageous. I would just ease off the accelerator to let it upshift.
I need advice. Should I be looking to drain and re-fill the transmission fluid or is this just normal?
I am confident that I can do the change and drop the pan.
The only thing I am not good on is how to accurately check the temperature when I go to refill the thing.
What is the easiest way to obtain a good reading? Can I use an existing sensor in the transmission?
I have absolutely no scanning equipment except for a DVOM.
If you are only going to empty the pan and refill, then the original fluid in your system is ATF 3403 from MB sheet 236.10. Since then, that specification has been superseded by a newer fluid called ATF 134 (from sheet 236.14). It might be OK to mix them, but it's better to flush the old fluid out using 14 L of ATF 134. The old spec ATF is still available.
P.S You don't need to replace the conductor plate. Yours is working just fine.
My INDI that checked it out after I thought I had a blown tranny said he found it on the bottom of the pan. He only uses MB filters because the clearances are specific and tight.
Worth a few bucks not to have an issue like mine.
Change is pretty straight forward if you are DIY.
Also I remember reading MB uses graphite clutches and this causes the fluid to get more of a grey color. I always thought brown=bad for t fluid. In any case time for a service.
PS also you probably want to change the electrical connector while you are at it. This is a know problem leak point for our trannys. Connector is cheap.
So now it is should I listen to him or not...
The car has 107,000 miles on it and the age of the fluid is unknown.
Do you guys think that the clutches have worn down and are now suspended in the fluid preventing it from slipping?
The SA was adamant, but do you think 107k miles is "too late" for a fluid change? it shifts normally with nothing extremely out of the ordinary.
Is my best bet to drain a quart or so from the drain bolt and examine the fluid and go from there replacing the lost quart with the ATF 134?
Please sway me as i am skeptical after what that Service Advisor told me.
http://www.benzworld.org/forums/w163...ml#post5550132
What did the SA advise you to do? Spend thousands on a new tranny?
The "if you change your fluid, your tranny might fail soon after" idea is very popular, but has little basis in fact. I suspect that they get old, and fluid gets changed, and they inevitably fail. But just because event A preceded event B, doesn't mean that A caused B.
To answer your original question, the fluid is red because of a pigment. Eventually, pigments decompose over time.
Because it says in the owners manual that the transmission is filled for life.
If any of you have the bulletin I would like to see it to see what they had to say about the "Lifetime Fill" Fluid.
I have thought it over and I have decided to perform the ATF change using the info already here on the forum.
I do plan on keeping the car for an extended period of time and it would be nice if it had the original engine and transmission too. So I think this is necessary for mainteneance.
I did my tranny flush a week ago, replaced with Marcon V. Works great ! Put it 4 quartz of tranny fluid. I drove 500 miles after my flush, and my fluid is now back to brown color. Probably needed a complete overhaul replacing filter and gaskets and connectors.
Thanks to forum, I had the courage to DYI this time on my tranny.
