help with trans problem ml320
Old Jul 27, 2013 | 04:05 PM
HugoPerez's Avatar
2002 ml320 sport
hi my 2002 ml320 is having transmision problems , i was going on the road and i just wanto to shift to 3 to seep up and it gave me a pul and would nos drive to i puled over and the trans stayed in 3 gear . i turn it off and it would drive for like 3 minuts and then stay in 3 gear again. so i diceded to drain the oil and the filter was clog up No metal particuls found , but the trans oil filter was realy bad , so i replace the filter and put the oil back, on a cold start it will **** to all gears and **** tronic with no problem, but on the 3 time i pase tru all gears it will stay like in 2 or 3 gear . dose any one know whats bad . any susgestion... took it for a diacnostic codes and they are p2500.... p2502... p220A...y316n2 .. y316n3
Old Jul 28, 2013 | 03:32 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
The first thing you must do is separate the 13 pin connector on the right side of the transmission. If it has fluid in between the two halves then you must replace the connector. After replacement, the "P" codes in the ECM must be erased and then the 3 digit codes in the Transmission Control Module must be erased.
If there is no fluid present, then you must replace the Electric Control Unit/conductor plate which comes with solenoids Y3/6n2 and Y3/6n3.
In any event, after every repair the "P" codes must be erased from the ECM and the 3 digit codes erased from the Transmission control Unit. If they are not your problem will continue even though you have made the proper repair.
Attached Thumbnails help with trans problem ml320-2013-07-28_032746.jpg   help with trans problem ml320-trans.-conductor-plate-electrics.jpg
File Type: pdf
Old Jul 28, 2013 | 03:10 PM
HugoPerez's Avatar
2002 ml320 sport
plug
hi thanks for the tip . and yes thier is plenty of oil . wen i puled the plug plenty of oil came runing down, i am going to buy the part . only thing is mb that is cosed buy never has time to scan or erase codes. may i ask how much and what kind of scaner do you recomend to erase the code mabye i can buy one on line ...
Old Jul 28, 2013 | 07:14 PM
Buy the part at a M/B dealership. Do not use and aftermarket part.
As for clearing the codes, find an independent mechanic with a professional grade scanner that has the Euro package installed, e.g Snap-On, and then he can clear the codes for you.
Remember that they must be cleared both in the ECU and ETC (trans. Module).
Old Jul 29, 2013 | 08:12 AM
HugoPerez's Avatar
2002 ml320 sport
part number
hi thanks for the advise, buy any way do you happen to know the part number or the name of this part so i can call mb and find out if they have it . o ps i drain the trany fuild and no metal particul wer found but i did find in the magnet some greyish sediments .
Old Jul 29, 2013 | 08:30 AM
Are you blind. The part number is on the plastic bag.
Old Jul 29, 2013 | 08:32 AM
HugoPerez's Avatar
2002 ml320 sport
sorry i was thinking it was just to show ,, thanks
Old Jul 29, 2013 | 08:33 AM
HugoPerez's Avatar
2002 ml320 sport
is the greyis sediment normal
Old Jul 29, 2013 | 08:40 AM
Yes it is.
Old Jul 29, 2013 | 07:03 PM
HugoPerez's Avatar
2002 ml320 sport
got it
just got the part and i cleand the conector and replace the part . turn it aon an it still dose the same thing now tomowor will take it for a computer reset any adcional info on this thanks a lot
Old Jul 31, 2013 | 03:21 PM
HugoPerez's Avatar
2002 ml320 sport
need more help
just had the ml 320 scan again and trans. and still not working codes are p2502 the gear is implavsible or the transmision is slipping .
p220A the speed comparison of y316n2 to y316n2 to y316n3 is implavsible any help please
Old Aug 1, 2013 | 02:42 AM
Were the codes cleared in both the ECM and Trans. Computer?
Old Aug 1, 2013 | 10:58 AM
HugoPerez's Avatar
2002 ml320 sport
yes they wer clear . i am going to purche the Transmission Electrical Plate , and then have it cleard again .. hope this works
.ps thanks for all your help
Old Aug 21, 2013 | 03:33 PM
HugoPerez's Avatar
2002 ml320 sport
just had the trany rebuild and now the check engin light came up again code is p2098 can u tel me what tht is
Old Aug 21, 2013 | 08:51 PM
Code P2098 has to do with a short in the SRS control module. I am not at all familiar with this code.
If I were you I would have the code cleared and if it returns you will have to see a M/B dealer.
File Type: pdf
Old Aug 22, 2013 | 07:23 AM
HugoPerez's Avatar
2002 ml320 sport
thanks for the help
thank you for the help i am so glade its not the tranny i senp about 2200 on parts and labor thank again let me run it for a day or 2 and see what up thanks....
Old Aug 27, 2013 | 07:04 PM
HugoPerez's Avatar
2002 ml320 sport
trany runing fine
hi just want to say thanks for all your help and your post , they rely help me out . just wanted to ask i check the fan cluch it was bad so i change it , what is a corect temp . ,y ml320 is runing at about 90
Old Nov 16, 2022 | 02:49 PM
damianaki's Avatar
ML 320 W163.154
Valve body for ML 320 1999 W163154
I am owner for a ML 320 W163 of 1999 and have problems with my Gearbox, Valvebody ar scratched and some part blocked, morever the conductor plate don't work I believe and the errors was DTC 147.
So I decide to change the valvebody. I am unsure if it the same for 722.6 and 722.662 Gearbox that my car have. Where is the difference between 722.6 and 722.662 ? Sould a valve body 722.6 should fit with my GearBox 722.662
Thank you for your assistance.
