ML 430 Key will not turn
Old Sep 3, 2013 | 07:30 PM
max2us's Avatar
ML 430
I have a 2000 ML 430 that likes to lock my key in. Every 14 to 16 months my key gets locked in and I cannot remove it from the ignition. Today, after playing with the key, it did come out but I could not start the engine, the key wouldn't turn. Yes, I played with the steering wheel, I moved the shifter to Drive, and Neutral positions, pressed the brake pedal, stood on my head and used my toes to turn the ignition key. Did not help.
The interesting thing is that it happened twice already in the last four years. The warranty for the tumbler is 12 months but they seem to die shortly after warranty expires. I have been searching about this problem for the last four years. Last year I had new tumbler and set of new keys cut too. The same issue today. There must be a problem with one of these components that they fail so often. If you have similar vehicle it will happen to you too. So, if you have any knowledge of this issue, please share your wisdom.
Old Sep 3, 2013 | 10:46 PM
CGL1's Avatar
'05 ML350 SE
Your problem may be the Lock Housing. #4 in diagram below.
http://www.parts.com/parts/2000/MERC...agramCallOut=6
Old Sep 3, 2013 | 11:54 PM
amx1397's Avatar
05 crossfire w/SL55 drivetrain installed by Rudy Compart Intake/Needswings best et-10.76 @ 129
maybe your key setup is the same or close read the thd. as it works and u never have to worry about it again, there have been a few on MB World fix the (((search sticky key))))jim
http://www.crossfireforum.org/forum/...n-key-fix.html
