Auto transmission problem with 2002 ML270 W163
Old Sep 7, 2013 | 12:00 PM
barudatang's Avatar
2002 ML270
I have a ML270 2002 W163 with a on and off problem with the auto transmission. The problem is the auto transmission will not change gear but after you shut off and restart the problem is gone, but when you off the engine, it comes back again.
Some observations are when you start the engine the low range flashed more than 5 times. When you put into drive the transmission goes in gear hard.
I've gone to my local MB guy and he try to check with diagnostic tool but when it reach the transmission level, the diagnostic comes up with communication failure.
Another matter, the switch cap for the low range came off. I'm ordering 1 new unit. Does this cause the above problem.
I really need an expert advice. Thanks all.
Old Jan 15, 2024 | 04:14 AM
meeloun's Avatar
e300
Proposal代写
拥有多年经验的proposal代写 http://www.baydue.com/store/info?id=6 专家是你取得成功的关键。这些专家具备丰富的学术背景和优秀的写作技巧,能够根据你的要求和学科领域进行精 准而全面的写作。无论是科学、社会学、人文学科还是商科,他们都能够为你提供高质量的proposal代写 服务。这些专业的proposal代写机构不仅能够保证论文的准确性和学术性,还能够确保美国论文的原创性 ,避免抄袭和侵权问题的发生。
Old Nov 12, 2025 | 12:38 PM
HenrikRP's Avatar
ML300 W164
I have this problem on a 2007 ML 320. The diagnose says "No signal from sensor Y3 / 8n2"
And another one "ETC (Electronic Transmission Control) Positive speedgradient to big"
The Y3 / 8n2 is a speed sensor in the Transmission Control Module. Selling fairly cheap on Ebay or other places.
Will replace the sensors ( I think there are 3 ) once recover from surgery.
