mercedes ml 270cdi blown fuse battery TERMINAL
Old Oct 30, 2013 | 09:35 AM
chrisadams's Avatar
ml 2.7 automatic 2003
yes about month ago filled up resefvoir and the hose leaked/came off and reservoir emptied
Old Oct 30, 2013 | 09:42 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
What about posts 23 and 24?
Old Oct 30, 2013 | 10:02 AM
chrisadams's Avatar
no power to radio
will check parking brake as soon as can just got to work for 20 mins
thanks for all advice/help
Old Oct 30, 2013 | 10:41 AM
You will have to access the Traction Control Module which is attached to the ABS Hydraulic Unit. Remove the appropriate headlight or the wheel liner on that side to gain access.
Washer fluid has a serious affect on the connector and its wiring. Remove it and inspect it thoroughly. Remove the covering of the harness and inspect for corrosion and wires touching each other or broken.
Refer to post #7 in the below link to remove the headlight
https://mbworld.org/forums/5224836-post7.html.
Attached Thumbnails mercedes ml 270cdi blown fuse battery TERMINAL-esp-ets-control-module-loc.-new.jpg   mercedes ml 270cdi blown fuse battery TERMINAL-2013-10-30_103125.jpg
Old Oct 30, 2013 | 12:13 PM
chrisadams's Avatar
many thanks.Will have a look at tomorrow as getting dark and v wet here
cheers
