Fuel Guage & Outside Temperature (Not Working) :( PLS Help!!
Old Nov 30, 2013 | 04:51 PM
Xiper-v's Avatar
Ml270
Hello there,
I am wondering if someone could help, I have not long purchased a Ml270 and is slowly learning.
I have an issue with the fuel gauge not working and the outside temperature reading - 38
I have read forums stating to turn the ignition on so you have all the dash lights on (just before starting the vehicle). Take fuse 5 out (cluster instrument fuse) and then turn the vehicle off.
Wait for 20/30 seconds and put the fuse back in.
(Once I have done this the fuel needle shoots up to full then slowly back down to 0 - with the engine running and after a long drive)
I have done this with a full tank, half a tank and nearly empty - as I have estimated a fair few times I can do 450miles before I run out. So every time I fill up a full tank - where I can see the fuel in the filler neck/basically to the brim and set my millage to 0.
As regards to the Outside Temperature I have bought a new air temperature sensor and have fitted it today and the reading is still -38.
I have even reset the instrument cluster hoping that this might solve it.
(I am correct in saying the sensor located in the front passenger side bumper? - must say looks like someone has already had a fiddle due to it being freely behind the bumper)
I am thinking about putting a multi meter to the sensor to see if I receive any current. Am I missing something or has someone else had this problem and resolved it?
Any help or information would be highly appreciated.
(Thankyou)
Old Dec 2, 2013 | 04:13 PM
art_arev's Avatar
2003 ML55,2007 ML63
Check the PDF's about your fuel gauge. The docs are for ML320.The only issue is if ML270 has the same or similar fuel pump in the same location as the ML320.
File Type: pdf
File Type: pdf
Old Dec 2, 2013 | 04:37 PM
Xiper-v's Avatar
Ml270
Thankyou bud!
I highly appreciate the docs, had a look through it and looks quiet simple enough (just fingers crossed things are the same). Shall get back to you with the outcome.
Thankyou
