2002 ML320 tie rod removal and replacement
Old Dec 10, 2013 | 02:10 AM
spkml320's Avatar
2007 ML350 4Matic Gasoline
I have worn front outer tie rods. How do I know if I need to replace the inner tie rods? Also what tools are required and what is the procedure for replacing the tie rod assembly. I will be working in my garage, not on a lift.
Thank you.
Old Dec 10, 2013 | 06:11 PM
art_arev's Avatar
2003 ML55,2007 ML63
You had your answer at Benzworld already!!!
