Battery disconnect switch considerations
If anyone has experience with this, please advise. Thanks in advance.
I have 2 CTEK US800 maintenance chargers, supposedly the same charger that is sold by Mercedes and Porche. I currently have an AGM battery in my ML500. The battery hold down bracket has a warning to disconnect the negative battery terminal while charging which is a pita. I currently leave the maintenance charger on my 190E for months at a time, without disconnecting the battery, with no problems so far but these are very different vehicles.
What is your viewpoint on leaving the battery connected while using a maintenance charger.
Mike
[EDIT] My thinking is that removing and/or reapplying the battery terminal could cause a surge or arc that could be more damaging to the electronics in the ML than properly connecting a maintenance charger.
Mike
