ML 320 2001 Bas/Esp
Old Mar 29, 2014 | 12:32 PM
Ml320 Norway's Avatar
ML 320 2001
Lightbulb ML 320 2001 Bas/Esp
Hi there,
I'd bought an ML in may 2013, and I love the car.
But these "lights of death" as I call them is annoying me so much. ABS doesn't work either. No good in the winter!
I took the car to an Mercedes dealer, a kind of specialist but not sertified MB Service I think. And I got some codes from the dealer.
He says the ABS pump needs to be replaced but I'm not sure I have to...
The lights are always on,from startup to shutoff. Except somethimes when it has rained and been cold /freesing) the lights and ABS works for a couple of minutes... It could seem like bad connections somewhere and the "frozen water" make the connection better??`
I attached photos of the codes from the Mercedes guy, I had allready changed the stop switch and checked the relay in the fuse box before going to him, but one of the codes are the stop switch, can I be so dumb and install it incorrectly?
Any ideas? Would surely appreciate some tips
Sorry if my English isn't as good as it should be.
Bjorn from Norway
Attached Thumbnails ML 320 2001 Bas/Esp-image.jpeg   ML 320 2001 Bas/Esp-image-2-.jpeg   ML 320 2001 Bas/Esp-image-1-.jpeg
Old Mar 30, 2014 | 03:47 PM
art_arev's Avatar
2003 ML55,2007 ML63
Please post the codes. The pictures are very small and get distorted.......
Check the brake light switch instalation in the document
File Type: pdf
Old Mar 31, 2014 | 11:13 AM
ML 320 2001
The codes are:
ESM Faults:
P1832-Output stage in ESM control unit (N15/5) has short circuit
P1861- Rear left wheel speed of traction system is implausible
P1860-Rear right wheel speed of traction system is implausible
P1817-Reversing lamp has short circuit to positive or negative
Old Mar 31, 2014 | 11:23 AM
ML 320 2001
Codes for BAS (HHT)
C1000 (5000)- N48 (BAS control module) Solenoid valve:Short circuit to ground.Short circuit to positive,circuit 30:open circuit
C1025 (5025)-CAN communication fault:ABS or engine module or stop lamp switch
C1207 (5207)-Stop lamp switch (S9/1) Implausible signal from sensor (A7/7b1)
Old Mar 31, 2014 | 11:27 AM
ML 320 2001
ESP (30_hht)
C1401 (5401) (status current)
C1401 High pressure return pump (A7/3m1) :open circuit/short circuit/always on
Old Mar 31, 2014 | 11:29 AM
ML 320 2001
Thanks for the install guide for the break switch, I watched youtube before changing it so I did exactly what you sent me
Old Mar 31, 2014 | 01:40 PM
art_arev's Avatar
2003 ML55,2007 ML63
Check relay #25.
You have C1401. This code means your ABS motor brushes are worn/finished. The brushes you need are L5-5H in the PDF. You need 2 of them. Get 4 just in case.This is a DIY. It will cost you a few hours and +- US$20-00 only. The dealer wants you to spend thousands of dollars on a new ABS pump....
This must be your main problem.After changing the brushes clear all the codes. You have recently bought the car so some codes could be old stored codes.
Good luck
File Type: pdf
Old Mar 31, 2014 | 02:04 PM
art_arev's Avatar
2003 ML55,2007 ML63
Let me give you a break down for the brushes. If there is a company that does custom brushes then they can cut it for you in 30min. I had my brushes cut........
ABS pump brushes:
5mm*5mm*13mm
38mm lead(copper braid)
Material :Copper M ( Metal graphite)
Very high current
Low voltage
Low resistance 12v & 24v
Speed medium
Old Mar 31, 2014 | 04:00 PM
ML 320 2001
Thanks alot art-arev
I have checked relay 25 alot of times. No problem there..
I have been into the brush idea, but this was only a guess, nice with tips from someone who have done it themselves.. I've found a place who hopefully can make the brushes closeby so I will call them tomorrow and ask. If not I will order from the website.
Can I unplug the whole ABS and bring it to the workshop?
Again thanks alot, I'm getting more positive about this now..
Old Mar 31, 2014 | 05:46 PM
art_arev's Avatar
2003 ML55,2007 ML63
You dont need to unplug the whole ABS. There are 2 bolts holding the ABS motor. You only need to remove the motor (A7 in the picture). You can do it yourself, noneed to take it to a shop. For more info read this. You will have all the info you need to do it yourself & save mega$$$$$$$$
http://www.benzworld.org/forums/w163...ghts-come.html
Attached Thumbnails ML 320 2001 Bas/Esp-abs-20pump-20motor.jpg
Old May 14, 2014 | 02:52 PM
ML 320 2001
problems fixed. 10 dollars
Yes. art_arev
The brushes were worn out, inside it was alot of dust. I understand why they have to change them every 10-12 years. But why is Mercedes Benz not informing about this? Only because of money? I called the local place that makes them and he had 4 perfekt pieces. 3 dollars each. Was fixed in an hour. Found some snow in the forest and hit the pedal, worked PERFECT .
Thanx alot for your tips art_
This is a heavy sled and I did not like a winter without ABS, very easy fix.
Old May 15, 2014 | 01:26 PM
art_arev's Avatar
2003 ML55,2007 ML63
I am happy it worked out for you.
Be safe & Good luck
Old May 19, 2014 | 05:59 AM
outbackjackinoz's Avatar
2000 ML270
Good info,
Wonder if same site has brushes to suit the coolant pump.......
I dont have the old ones, so cant measure them any more....
Old May 19, 2014 | 01:57 PM
art_arev's Avatar
2003 ML55,2007 ML63
Originally Posted by outbackjackinoz
Good info,
If you are referring to the AUX coolant pump don't even try.......Get a new VW one.
Old May 19, 2014 | 06:50 PM
2000 ML270
Yes I was referring to the AUX Coolant pump.
A new VW one maybe an option, but if you could replace the brushes for a few dollars, that would be a cheaper option. Not sure on cost of the VW option.
Old May 22, 2014 | 07:58 PM
art_arev's Avatar
2003 ML55,2007 ML63
If the brushes are gone then the plastic brackets/seats where the brushes are held in are gone too. Everything will be sort of melted/disintegrated inside. You will never be able to fix it.....Get a VW one. That's your best & cheapest option
