I knoweverything there is to know about the ML
#53
MLgod...02-ml320. I got a couple problems.. After driving for maybe a half hour, the abs modulator starts to run continuosly, even after turning vehicle off and key out, still runs untill i pull out relay k25 for the abs.
The other concern is The audio system, got the old classic no sound and cdc not reading, how can i tell if the problem lies in the fiber optics or in the cdc, or even the amp? A lil lost here and any help would be greatly appreciated.
#55
Waste of time posting on this thread ML God has not been active since 2006
Who rekindels old threads![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
People it's now time i'm interested in,![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
Active members so you can get answers to problems
#57
ML 320
Maybe you can help me with some issues on my 98' 320. We've had this car for over 10 years and it has been very reliable. Most problems it has had have been minor. The 320 has about 160K miles on it. Here are it's current problems:
1. Keeps blowing the 10 amp fuse that supports the overhead info center, vanity lights, glove box light and ashtray light. It blows at random times. A new one could last a week or just a couple of days.
2.The radio quits after going over large bumps sometimes. It comes back later though. Maybe just a lose connection at the radio I suppose.
3.Auto dimming mirror on off light no longer works. I did not see a fuse that supports it and I have not checked for power at the mirror.
4.The engine turns over quite a few times before starting if you let it sit more than a couple of minutes after turning it off. If you crank it right away after turning it off it starts instantly.
#58
I recently picked up a 2002, ML500, 70k miles. So far everything seems fine, except
1) on every other try, the right hand turn signal will not cancel. I can live with it, but is this a common problem and difficult repair?
2) Is there anything special I should be checking or looking out for at 70k miles? The vehicle came with detailed service records (a real plus). Recently replaced cd player, radiator and power steering hoses under extended warranty (glad I got one).
3) What's your opinion on transmission fluid changes? Is is worth the hassle and expense or should I just risk "lifetime" fill?
4) Is there a source other than the MB DVD (instructions) for brake pad replacement and spark plug replacement (I like to do my own soon)?
Hope I'm not too greedy with the questions but could not resist. Thanks in-advance for the advise. PS: My wife loves driving this "tank." Feels smooth, safe and powerful.
#59
ML 320 no power
I have a 2001 ML 320. This morning I started my car and at the same time pushed the turn signal/high beam handle at the same time and it died. Don't know if that had something to do with it or not.
I attempted to restart but NO power. No instrument light, door locks, windows, radio and et. Dead, Dead, Dead.
I found the two fuse panel locations and found one two fuses blown and replaced. But nothing, still dead.
I got one of those 12v light testers and saw my battery had power.
I then went to the fuse panel in the engine and took the cover off and found where the battery cable was coming in and I had power to it.
I found I fuse there (of the two blown ones) and replaced and still dead. No power.
Any suggestions???
Need Help badly.
Any suggestions???
Need Help badly.
#60
Vaccum Hose Replacement
I've got a 2000 ML430 and my vaccum hoses have rotted. There's one that has broken and goes under the intake manifold and I can't see where it attaches. Can you help me get access to it.
#61
i have a 2001 ml320 it giveing me so much problems , i was driving an my truck slide like i was on ice ,i try to press the braks no braks. the next day i took it to the dealer to get it check an thier told
#63
![Unhappy](https://mbworld.org/forums/images/icons/icon9.gif)
Hi! hopefully someone can help me out with this problem. When I move the transmission selector from parking to D or R on my 2000 ML320 the transmission shifts but the transfer wont engage, and there is a grinding noise inside it, at first I thought the problem was mechanical but researching the issue I came up to the conclusion that it could probably be an electrical problem too. Any ideas? Thanks
#65
D pillar is part #1636900687 right and 1636900587 left, they are 67.85 each at parts .com my total was 158.00 after shipping and handling. Its oem factory made(dont know if thats good or bad). I just got mine now I need to install them, not sure if I should us double sided tape or urithane?
#66
Let me know
Let me know what happens, Ive read urithane is better but I havent gotten mine yet. I found a guy thru my work that has a brother that can hook me up with the parts and he might be able to install for me as well.....but Id be curious to hear how u did them.
#67
Hi, How do you replace the right side exterior rear view mirror LED turn signal lamp. The LED turn signal lamp in not working. The manual said to bring it to a MB service center. How hard can it be to replace it. Thanks in advance.
#68
Water pump DIY
Hi, I need to replace the water pump on my 2003 ML350. I was wondering if someone can send me a DIY or some heads up about any tricks? I assume I need to remove the fan cowling first (after battery negative terminal of course). THanks, T
#69
Flaking rear glass in ML's
I had 'flaking' paint on the rear plastic side panels on my 2003 ML350.
I read that the panels are plastic which have high elasticity and thus the thin laquer gets cracks and flakey due to prolonged exposure to heat and cold.
I found that light sanding with a fine sanding block (120#) and then hard rubbing with very fine steel wool (elbow grease) will remove the flaking paint and make the panels look pretty good.
#70
heater control unit - how to remove ? 99-ml320
Issue: several days ago the heater would only "heat" no matter where the temp dial was set. Next day it was ok. Day before wife noticed a ticking sound when the temp dial was on "circulate - full rotate to left and two click up from this. Heat seemed to vary based on where the dial was moved. Today I can not get any heat going to work. No ticking noise.
What is the best way to self diagnose this? I bought the car used and have driven it almost 80K and the wife keeps it looking like the day we bought it. Have spent some money at the dealer but want to keep it to a minimum if I can.
Thanks.
#71
my 2004 ml350 bas/esp light came on and first problem it wouldnt let me put in park while car is on so i have to turn it off in neutral in order to put in park while i put in reverse it jerks and then when i start driving it wont shift out of first gear any recomendations ? would gladly appreciate
#73
I have a question about a 1998 ml 320 the aux light swith lights up but nothinghappens to the lights I recently replaced the head lights with projector lights and found a Plug that was never hooked up i wonder if it was an option and is this plug for the switch because i would like to add hid fog light to the lower cowl
