Question from a Newb
I recently purchased my 2nd MB...a 2001 ML 430 Sport. It's a great ride, however I've noticed something odd. I filled the tank up a few days ago and now I sit at less than 3/4 of a tank. the problem is that I only show 28.7 miles since my last fill-up. Not very good economy, if you ask me...anyone else had this problem. If so, how did you resolve it? Thanks in advance for the insight.
Thanks for the input, ML God. From the posts I've seen, you seem to be the resident expert. Would a bad fuel sender also make my "check engine" light come on? Because that happened a few days ago and it is still on. Seems to be a common problem on the board. Thanks again.
Ironically my check engine light came on after the fuel thing...it ended up being a bad MAS = mass air flow sensor!
Good luck
I guess I have to assume I always have a 1\4 more gas than whats shown!
I also have the gas gauge do the same thing.......
However, when the pump automatically shuts off the first time, I keep trying to fill more till I can seee the gas a bit.
The gauge then moves up higher.....
I believe the gas pumps shut off too quick! A gas attendant mentioned this to me as well.
