Windshild wipers not returning home
Old Dec 23, 2014 | 02:59 PM
stumpan's Avatar
2005 ML350
Ok, I have seen several other threads on this in other models but nothing on the w163.
I have a 2005 ML350. When the wipers are on they seem to work fine, but when turned off, they do not return to home... they stay where they were when the switch was turned off. I have read there could be a bad relay, where is this relay located or is there something else I need to look for? I have also heard the relay could be on the motor itself.
Old Dec 23, 2014 | 04:14 PM
art_arev's Avatar
2003 ML55,2007 ML63
Relay K17 engine bay fusebox.
Old Dec 23, 2014 | 04:44 PM
stumpan's Avatar
2005 ML350
Thanks Art,
Well, I replaced the relay with 2 others of the same type and it did not fix the issue. Looks like it may be something deeper. Any other ideas?
Old Dec 24, 2014 | 03:51 PM
Mike's ML's Avatar
1990 190E 2.6, ... 1998 ML320, 2005 ML500SE
The park switch is inside the wiper motor assembly.
Did you try running the wiper for a few minutes, stopping occasionally, to see if you can mechanically clean the contacts. This worked for my 190E which had the same problem. The park contacts get grease and oil on them from lac of use and can often clean themselves off from being actuated on and off.
Mike
Old Dec 24, 2014 | 04:02 PM
stumpan's Avatar
2005 ML350
Thanks for the information... Wife came in this morning and asked what I did to the wipers. I started to freak out and she explained the wipers worked fine now... That could explain it. Ill keep an eye on them. I found out it was either the motor or the rain sensor, just didn't know where to start.
