ML 430 runs on choke and sucking gas like hell
Old Jan 6, 2015 | 09:21 PM
Racka0's Avatar
ML 430
Hi Guys ,
I have a 99 ml 430 from 7 years now . The car has 105 000 miles . I always maintain the car, probably that's the reason its looks and rides like new .
But I am not happy with a gas/mileage anymore . This vehicle gave me 18-20 mi/g in city and 20/23 highway . NOT ANYMORE. Something just happened !Now the most I can get( and its does not matter where I use it) is 14-16 mi/gallon . What I am noticing is when I start the car it runs on choke quiet longer than it use to ..(at least 1 minute long now ,and it was 20 sec before ) Also when the car runs on choke and I put it to gear its almost dies . But after the choke goes away and the rpm dropping the car runs smoothly without any issues .
I need an advice .If anyone could help please let me know what to clean or replace .
Here is the list what I just replaced since its happened: -new fuel filter , -new air filter , air mass sensor cleaned , new plugs , but nothing changed .
THANKS
Old Jan 7, 2015 | 05:14 PM
Racka0's Avatar
ML 430
Any Ideas?
Old Jan 11, 2015 | 09:31 PM
farcohollis1369's Avatar
'02 ML500
I'm no authority on these Mercedes systems, but other fuel injected cars I've owned depended on a temperature sensor that worked as the "choke". The colder it gets this sensor tells the fuel injection system to feed more gas (fast idle) until it warms up. Sort of an "electronic choke". I assume this system depends on the same principle. If there is one on there, it could be this temp sensor not working properly.
Old Jan 11, 2015 | 09:40 PM
Racka0's Avatar
ML 430
I am still trying to find the issue .
Thanks for your advice .
Old Jan 11, 2015 | 09:53 PM
'02 ML500
No problem.
I will think about your wheels also.
