My ML's motor got noisy off late..
Old Jan 16, 2004 | 03:01 PM
mihir_d's Avatar
2000 ML320 2006 SLK 350
I just got my B service done last month at 70,000 miles...then put the ML off for a month in my garage, while I was gone on vacation....came back and started my ML.
Started right away without any hicups...and I drove it off....in a minute or so...I felt something different about the motor noise....as I give gas to the motor...it almost sounds like a steam engine reving up....I brought it to a stop and let it idle...the idle noise has changed too...with a mild synchronus put putting sound coming off the exhaust...unlike the smooth running sound of the motor..
I called up the service center and am taking it for a checkup tomorrow...in the mean time does anyone have any insight into this?
The temperatures are also kind of low here at this time of the year...but not lower than 30-35 degrees...
Old Jan 16, 2004 | 05:24 PM
mihir_d's Avatar
I'm told its most likely the Catalytic Converter...
I had an MB technician hear my motor...and he feels its definitely the catalytic converter that needs to be replaced...
How common is catalytic converter failure on the ML??
Old Jan 17, 2004 | 03:36 AM
Sincity's Avatar
I just had my driver side (ML) one replaced recently at 61k mi. I think it is a Federal Law that CATS have to be warranteed for 75k mi. I now have an annoying rattle that won't go away.....I wonder if it is a heatdhield they didn't tighten?
Old Jan 17, 2004 | 10:33 AM
mihir_d's Avatar
Where did you get your's replaced??
Thanks for the info...I am under 75K miles...I will first talk to my MB rep today about the fedral law...and see if that works...
I did some research on the CATs and it seems there are tonnes of aftermarket vendors for these..
What's the general advice...stick with MB or are aftermarket ones equally good?
From the noise pattern, mine seems to be the driver side one too...that needs replacement..
I am taking it for a full inspection today to the MB..so will post the outcome in day...
Old Jan 17, 2004 | 10:47 AM
mihir_d's Avatar
Here's what I found about the warranty..
Clean Air Act Warranty Provisions (42 U.S.C. S 7541 (C) (3) (B))
The federal Clean Air Act requires vehicle makers to provide two emissions-related warranties -- a production warranty and a performance warranty. The production warranty requires the vehicle maker to warrant that the vehicle is designed, built and equipped so that it conforms with emissions requirements at the time of sale. The performance warranty requires the vehicle maker to warrant that the vehicle will comply with applicable emissions requirements as tested under state vehicle emissions inspection programs for the warranty periods specified in the law (for model year 1995 and later vehicles, the warranty is 2 years/24,000 miles for all emissions-related parts and 8 years/80,000 miles for the catalytic converter, electronic emissions control unit and on-board diagnostic device). The performance warranty is conditioned on the vehicle being properly maintained and operated.
Like the Magnuson-Moss Act, vehicle manufacturers may not refuse warranty repairs under the Clean Air Acts performance and defect warranties merely because aftermarket parts have been installed on the vehicle. The only circumstance under which the vehicle manufacturer can void the emissions warranties is if an aftermarket part is responsible for (causes) the warranty claim.
Old Jan 17, 2004 | 10:49 PM
ML God's Avatar
Re: I'm told its most likely the Catalytic Converter...
very very common, They crack at the weld. more than likely your motor mounts are bad which caused it to crack
Old Jan 19, 2004 | 10:54 AM
mihir_d's Avatar
And how common is motor mount failure??
My previous service, a month ago, I was hinted about the motor mounts having flattened a bit, but was also adviced that, it was not a major problem, except for a mild vibration at start. So, I kind of ignored it..
Seems like this is a real shoddy quality vehicle after all...at 70,000 miles I already have a list of major components to watch for..post warranty
1. Harmonic Balancer
2. Motor Mounts
3. Catalytic converter
4. Auxillary fan wiring/harness
5. ESP Lateral stability sensor
This excludes a list of about 10 more things that they replaced under warranty...
1. Skyview roof
2. ESP Lateral stability sensor
3. Fuel injection system
4. Window switches
5. Radio wiring and antenna
6. Steering hose/clamp
7. Fuel injection system
8. ...
9. ...
10. ... I can't even remember all of them...
Now, I am really wondering...is this vehicle worth keeping after all? I had plans of keeping this for 10 years....its not even 5 years yet...and this list is just growing...
Old Jan 19, 2004 | 11:32 AM
azinn's Avatar
2014 RX 350 F Sport, 2007 Scion tC, 2000 ML 430 Money Pit Finally Gone! Oh Happy Day!
Re: And how common is motor mount failure??
Seems like this is a real shoddy quality vehicle after all...at 70,000 miles.
I feel you pain.............. I've been keeping my fingers crossed ever since mine went out of warranty last month. I've got around 53,000 miles on it now and no extended warranty. If I get to the point that it costs more to fix it than its worth, then I get rid of it. Probably go to some Japanese brand next. Hate to say it but this is the worst car/truck I've ever owned. I've had a little over $16,000.00 in warranty work done on mine.
Old Jan 20, 2004 | 04:12 PM
mihir_d's Avatar
They'll cover the CAT at 70000 miles...
I was told, they will replace one or both the CATs (as needed) under warranty. Its 8 yrs./80000 miles for all vehicles manufactured after 1995. That's what the fedral law states. All critical emission related components are covered for that long..
Someone pointed out that one of the several causes for the CATs to fail on the ML is flattened motor mounts.
I was hinted thru my previous service that my motor mounts had flattened a bit. Now, what's the advice, should I get them replaced as preventive maintenence along with the CAT? (Of course I will be paying for the motor mounts...they won't cover those)
How likely is it for the CAT(s) to fail again because of the flattened motor mounts? My guess is that although they have flattened only a bit now...they will get worse by the day....and that would be like risking the newer CAT(s) further.
Old Jan 20, 2004 | 08:20 PM
mihir_d's Avatar
Its $2700 in total repairs...
Here's the final verdict...
Both CATs are bad...$700 for the passenger side one and $1600 for the driver side one..both are cracked at the weld...
$400 for the motor mounts...
Fortunately, MB will cover the CATs since I am under 8 yrs./80,000 miles. I am just saved of having to spend a fortune on fixing this one....
But, I still pay for the motor mounts...
ML God...you there??? you are an MB Tech...what's your honest advice...keep this truck...or should I start looking for another one....
Owning the ML is really starting to look scary now...
I also see after market motor mounts selling for $30-60 a piece...some even claim better performance (polyeurethane ones) than the stock rubber ones...what's the general advice, stick with MB, or go after market...I am sure, I can get them replaced for about $250 after market..instead of the $400 at the dealership...
Old Jan 20, 2004 | 10:08 PM
ML God's Avatar
Re: Its $2700 in total repairs...
Yes I am here...I am a MB Tech. I would hold on to your vehicle....if it is paid for. Right now I am leasing a 2002 ML 500
Old Jan 21, 2004 | 01:07 AM
mihir_d's Avatar
Yep...its all paid up...
And I had it all jazzed up with all the MB accessories from fender flares to chorme side steps/grill guard..even a Lorenzer spoiler and all the fancy options on it like the folding side mirrors, skyview roof, Nav and and all that...$50,000 out of the door...for a ML320.
I bought it with full intentions of making it a once in a life vehicle..something that I would keep forever...at least until 2010...
I still can't deny how thrilled I am with its ride quality and performance...but can't help being worried about its reliability..
I am already warned about the harmonic balancer, something to watch for in 2005.
Its still the beginning of 2004 and I already have 2 problems lined up to be fixed.
1. CATs
2. Motor mounts
In 2003, the highlights were
1. ESP Lateral stability sensor
2. Auxilary fan wiring/harness/fuse
In 2002, the highlights were
1. Skyview roof
2. Window switches/MCS Radiio wiring/antenna
In 2001, the highlights were
1. ESP lateral stability sensor
2. Fuel injection system
plus all the little trim pieces that they have kept replacing through the years...
I only wish MB had made this a lot more reliable than this..
