Noisy Climate control
Old Jan 18, 2004 | 09:51 AM
milltek's Avatar
1999 ML430 2009 C300 4Matic Lux
Hi,
Our CC unit has suddenly started making a noise. Its like a click-click that is in time with whatever fan speed is selected on the climate control unit. Almost like something has fallin the way of the fan blades. Has anyone else had this and what is the cure?
The car is a 99 ML430 with 58000 miles.
Jim
Old Jan 18, 2004 | 11:33 AM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Most likely something like a piece of paper, twig or leaf has made its way into the fan area and is hitting the fan. Worst case would be a bad bearing on the fan motor. Fan area must be opened up and inspected.
Old Jan 18, 2004 | 11:40 AM
milltek's Avatar
How do I open up the fan area?
Jim
Old Jan 18, 2004 | 11:43 AM
sosh's Avatar
Never have done that but I believe if you remove the filter which I understand is under the dash on the pass side you have access to it. Perhaps someone else on this forum can give you more explicit directions, or, go to your dealer
Old Jan 18, 2004 | 05:13 PM
f4i 954's Avatar
2009 e class 2012 ml350
Whre is the noise coming from?
Not shure what was the first year for this (99 or 00), but if it`s coming from the center vent the lock for the positioning motor is broken.
If its coming from the fan area, you have to remove the passenger under dash panel to access the blower motor.
You will need a t20 torx to remove the blower.
Old Jan 18, 2004 | 06:14 PM
milltek's Avatar
Hi,
Problem solved. An enormous leaf.
Thansk for the input. It was great.
Took the filter out as well for the first time. (We got the car used last July). Never saw such a dirty filter in my life. A new one will be acquired tomorrow.
Jim
