fog lights
Old Jan 25, 2004 | 01:33 AM
mdstran's Avatar
ML 430
fog lights
any recommendation what kind of fog lights i can install underneath my bumper is it a DYI PROJECT
Old Jan 25, 2004 | 03:35 AM
Sincity's Avatar
Yes DIY. You can get the ones that plug directly into the factory harness from performanceproducts.com or any other brand and splice into the factory harness. After installing the lights, you need to have the dealer activate the fog lamp switch.
Old Jan 25, 2004 | 09:27 PM
mdstran's Avatar
ML 430
there is two kinds the hella FF100 DRIVING OR FOG and a micro DE FOG LIGHTS WHICH ONE IS BETTER
Old Jan 25, 2004 | 10:55 PM
Sincity's Avatar
I dunno. Sorry.
Old Jan 26, 2004 | 12:58 PM
RezaR1's Avatar
2019 GLC 350e
I have the Micro DE and I love them. It fits perfectly and the installation took about couple of hours. I got them from a different source other than PP which meant I had to fabricate my own brackets and wiring harness. Still it was an easy installation
Old Jan 26, 2004 | 09:28 PM
Sincity's Avatar
You also had to fabricate a harness? Couldn't you simply splice into it?
Old Jan 26, 2004 | 10:57 PM
mdstran's Avatar
ML 430
which one has better illumination ff100 or micro de
Old Jan 27, 2004 | 01:06 PM
RezaR1's Avatar
2019 GLC 350e
Maybe I should have reworded that differently. By fabricating, I meant that I had to do some cutting on the Micro De side and cutting on the factory wire side. I also used male-female connectors.
Old Jan 27, 2004 | 03:04 PM
Stiggs's Avatar
2003 CLK55
I have the hella FF100's on my ML. Love them.
Had an independent garage install them for me.
Do a search on this forum for fog lights...also check out Benzworld.org, they have a lot over there on the fog lights!
Old Jan 27, 2004 | 10:34 PM
Sincity's Avatar
Reza,
Thanks for the clarification.
Old Jan 28, 2004 | 12:01 AM
RezaR1's Avatar
2019 GLC 350e
If you go to Hella's website, they have majority of their lights on there with the illumination patern. I chose the Micro De becuase it had the best pattern and brightness out of all the ones that I saw.
Old Jan 30, 2004 | 02:47 AM
mdstran's Avatar
ML 430
really but do you think you can change the bulb in that micro de fog lights because i think on the hella ff100 you can change it correct me if im wrong
