2000 ML 320 transmission stuck in 4th gear
I have a problem with my automatic transmission in my 2000 ML 320. After about a half hour of driving, it seems the tranny gets stuck in 4th gear. So when I come to a stop and try to accelarate again it takes off extremely slow. Also it will not go into reverse either. When I try to put it in reverse it just reves like it's in neutral. If I shut off the engine and then restart it immediatelly it will be OK!!!. (Untill it does it again in a half hour)
Can anyone please help?
Read more about this problem here: http://manual.startekinfo.com/manual...d1/2_3/m11.jsp
In order to prevent damage to the automatic transmission in the event of an
mechanical-hydraulic fault,
the transmission shifts into 3rd gear and is held in this gear, or
the transmission shifts to the last "known good" gear and is held in that gear.
This type of limp-home mode is reset by turning the ignition OFF,
and then ON again.
As for trans fluid changes, if your fluid is 120,000 miles old, it makes more sense to change as much as you can for new fluid. What's the point of mixing 4 quarts of new fluid with 5 quarts of old black stuff? There is no reason to be afraid of servicing your transmission.
I suppose reading and believing the opinions of doomsayers could be a reason for fear.
EPC states that the transmission for my 1999 ML 320 VIN number 4JG1631541A129869 is 722.662 . I have the opportunity to buy a transmission 722.606 from an E class Mercedes 1999. Does anyone know if the electronic module fit? The codes I had read state that the "speed sensor / electronic module is faulty. Mercedes charges too much for it and I have an opprtunity to buy an entire transmission cheaper in good condition, but I only want to change the electronic module above the valve body. Please advise. Thank you
If you had a punctured tyre, would you buy a whole front axle?
If Mercedes charge too much, you should seek a quote from an independent transmission specialist. It is a job I reckon you could do yourself, if you can get the tools, do the homework, and make the time.
Watch a few of the videos in this series and you'll find out how easy this is:
www.youtube.com/watch?v=bdt4g5jqo4E
Thank you all for chimimg in. I appreciate your expertise
Kingfloyd, I think you are confusing things......What electronic module are you talking about? The gearbox from the E class will not include any modules. Are you talking about ETM? If you are talking about speed sensor, then it must be the conductor plate.
I don't know why you are not buying it online. You can get it from E-bay UK.
Do not buy a second hand unit.
