How can I lock the door? The passenger door won't lock even manually?
Old May 24, 2015 | 02:56 PM
LukasBMW's Avatar
2025 BMW I4, 2018 Alfa Romeo Giulia Quadrifoglio, 2008 ML550
Title says it all.
The passenger side door of my 2003 ML500 won't lock even if I push down on the plunger.
I just want the door to lock (to secure the car) until I can replace the component. Is there any way to do this? Is there a trick?
Both rear doors only lock manually, but at least they lock.
Old May 25, 2015 | 01:33 PM
DrX's Avatar
DrX
2002 ML320, 2003 A160
Does the central locking button on the dashboard work? If not, you can probably fix that first.
http://manual.startekinfo.com/manual...6/20_1/m13.jsp
Old May 25, 2015 | 03:17 PM
LukasBMW's Avatar
The central locking button on the dash works on most of the doors, but the rear passenger door is hit and miss.
The front passenger door won't lock with the dash button.
It won't lock no matter what I do. I can't even lock it if I depress the plunger.
Old May 26, 2015 | 12:00 AM
DrX's Avatar
DrX
If the central lock button can lock all the doors except the front passenger's, then the only trick to lock it is to fix the broken lock. Or replace it.
Art has successfully repaired his lock actuators without needing to replace the whole assembly. --> http://www.benzworld.org/forums/w163...l#post10948634
If the lock doesn't respond at all, it might not be plugged in. Open the door panel and check the wiring. Maybe the previous owner dealt with machine gunning by disconnecting it.
www.youtube.com/watch?v=NethHVb59B8
Old May 27, 2015 | 02:06 AM
LukasBMW's Avatar
Good info. Thank you!
Old May 29, 2015 | 02:50 AM
LukasBMW's Avatar
Unhooking the power from the door stopped the machine gunning.
The lock wouldn't stay down even without power. I ended using a zip tie to keep the plunger depressed.
It actually works perfectly. The door will still open from the inside but stays locked outside.
Perfect temporary fix.
Old May 29, 2015 | 03:15 PM
art_arev's Avatar
2003 ML55,2007 ML63
Lucas, have you seen your profile? The cars which you don't own are there, but the car you do isn't.
Please do something about it.
Thanks.
PS. Open the door panel , get the actuator out. Open it & find out what is wrong. Zip tie????? Really???
Old May 30, 2015 | 12:29 PM
DrX's Avatar
DrX
It was machine gunning? It would have helped if you had described the fault a bit more accurately.
Old Jun 27, 2015 | 02:10 PM
Carole Wright's Avatar
2003 ML 350
Central Locking only with Remote Key
My central locking system works fine with the key fob, but the console switch no longer seems to work. My car was stolen, then recovered, earlier this year. The dealership ordered me a new key, and programmed it. I seem to be experiencing various gremlins now.
Oh, and the doors never have automatically locked when I begin moving. I didn't know that they were supposed to do so, until I read my owner's manual. 😯
Old Jun 28, 2015 | 05:41 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Are you looking for help or just making a statement?
Old Jun 28, 2015 | 09:39 PM
2003 ML 350
Sorry about that! It's not a crisis, but I'd love some help, thanks!
Old Jun 29, 2015 | 04:20 AM
What are the gremlins?
Does your Central Locking work, now that you have read the manual?
Old Jun 29, 2015 | 12:14 PM
2003 ML 350
No, my central locking still doesn't work from the console. I tried holding the button down, still nothing. I believe that the "Lock while in motion" feature can be disabled, and perhaps the previous owner did so. Central lock from console always worked up until the theft, though.
Other gremlins... Off the top of my head, sometimes the switch needs to be held to get the windows to go fully up or down; sometimes the front air blower won't come on; sometimes the mirrors fail to tilt downward when I reverse; more and more often, the navigation unit won't read the disc (ordered a cleaning kit); and I'm having a weird deal with the car revving and acting like it's stuck in 1st gear when coasting at low speed, then lacking acceleration from a stop. (MAF sensor?).
Thanks in advance for any advice! 😊
Old Jun 29, 2015 | 10:23 PM
All of your problems, except for the eng. revving, are confined to the switch console.
The first thing to check is to see if fuse #42 and relay K20 are in place in the fuse/relay box.
If they are in place, then what you will have to do is remove the switch console and see that the three connectors are fully snapped in.
And no, the MAF Sensor is not the cause of the revving.
Attached Thumbnails How can I lock the door? The passenger door won't lock even manually?-fuse-42.jpg   How can I lock the door? The passenger door won't lock even manually?-k20.jpg
Old Jun 30, 2015 | 01:14 AM
2003 ML 350
Thank you so much, Major Dundee! I will check that fuse and relay in the daylight tomorrow!
