2002 ML320 Electrical Problems
Hello Everyone,
I've been a frequent reader, but I'm a first-time poster. I am have several issues with what seems to be unrelated electrical systems. I'm hoping that someone can help point me in the right direction. I'll start with a list of symptoms:
My first thought is that it might be the AAM, but then I've been reading that there could be some ground issues. Perhaps a mixture of both? I'm not an electriction, but I'm not afraid to try new things.
Thank you so much for your help! |
1 Attachment(s)
Originally Posted by onegregwiley
(Post 6515009)
Remove the panel under the driver's instrument panel and access the brake light switch. First check to see that it is partially blue in color. The blue colored switch confirms that it was replaced per a recall. Regardless if it is blue or not, remove the elec. connector and twist the switch clockwise and remove. Then follow the instructions in the pdf. Pull the pin out all the way, manually press down on the brake pedal and insert switch and lock in place. Then release the pedal and pull up on the brake pedal and connect the connector. Then see if any or all of the problems recur. If you do not have a blue switch, go to a dealer and purchase the latest one, #001 545 95 09 and install the new one the same way as above. https://mbworld.org/forums/m-class-w...ml#post5812567 https://mbworld.org/forums/m-class-w...ml#post5039586 |
Originally Posted by Maj. Dundee
(Post 6515459)
(Post 6515009)
If you don't have an owner's manual, you can download one. |
UPDATE
It looks like my idle voltage is significantly lower than it should be. It is currently at 11.9.
I will be changing the alternator at this point as well. |
Your ML may have an emergency call system that mutes your radio so the call centre operator can hear you. Sometimes the e-call module thinks you've crashed and starts calling. |
There is......Read post #9. Buy the loop, install it, then remove the module & throw it away.
I have edited my post. I forgot the OP is still going to use the MCS. |
Originally Posted by art_arev
(Post 6520429)
There is......Remove it & throw it away
Don't you also have to instal an FO bypass adapter and reprogram the FO ring assignments. I have been wanting to remove my telaid unit since I bought my ML500. Mike |
Originally Posted by Mike's ML
(Post 6520656)
Art,
Don't you also have to instal an FO bypass adapter and reprogram the FO ring assignments. I have been wanting to remove my telaid unit since I bought my ML500. Mike You certainly do and here is how to do it. M/B part #000 545 33 84 and cost approx. $5. |
(Post 6520656)
Art,
