ml 350 power steering reservoir
If there is a leak, it is the seal between the pump & the reservoir. No need to replace the reservoir, only the seal.
If it whines, it could be the diaphragm inside the reservoir. It can break. In this case you need a new reservoir + new seal.
Buying original reservoir &/or seal is very important.
Stick your fingers under the reservoir & see if its the source of your leak.
Second option is the hose from the steering rack to the radiator.
Were is the leak? Is it on the left side under the radiator or under the PS pump?
If it is option 1 , then get a new seal. Option 2 requires a new upgraded clamp.
