2002 ML 320
Old Nov 30, 2015 | 12:32 PM
Rocking BlackML's Avatar
ML 320
2002 ML 320
Hi Joe here my 2002 ML 320 Base has manual seats
I have located Power Seats from Similar sport model
Is it possible to swap manual to power?
Wiring issues?
The replacement power seats are heated
But my dash lacks a heated seat switch
I'm not concerned about having heated seats
Just concerned with power movement adjustability
Please advise ?
Joe
Old Dec 2, 2015 | 08:47 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
The answer is yes providing that certain things are in place:
a. that connectors X55/3 and X55/4 are in place. Probably under the rug.
b. in the right side kick panel fuse/relay box there will be no relay K1 in place because you do not have power seats, but you must inspect the four cavities of vacated relay K1 to see that they have contact points (silver dots) to enable the relay to work.
c. the same goes for fuse cavities 10 & 11.
The only draw back is that you will have to see a dealer to activate the AAM to operate the K1 relay or the wiring has to be hot wired to activate the relay.
File Type: pdf
File Type: pdf
