Problems on ECU ml 55 amg 2002
Hello everyone, my name is Stephan , I'm french , and I bought a great deal on a 55 ml amg 2002 because of various problems , it is almost finished except a default on the lambda probe 1 , my computer myself gives the defects and p0130 P0135 , 4 probes are new, there was this one ml e85 kit that the former owner had tried to change , it is possible that the ECU is damaged , the defects are P0135 and p0130 lambda probe error 1 or cable wiring error or eCU error, the technician mercedes garage does not know this model , I would be on my problem before ordering an ecu ,, thank you in advance, and especially vivid Mercedes
being very overwhelmed by my job and work at home, I rarely use the ml, and I rarely have time to look at me
2 p0130 fault codes P0135 and Being still present even after replacing 4 lambda sensors, I continued to look further, the problem comes from the probe before I left when facing the car when I bought it there was a e85 kit installed above but partially offline, part of wiring was taken on the probe in question connector fittings, a domino short a crappy job, the 2 fault codes are: default heating circuit and data, of the probe or the circuit or to the ECU, the probes are new, I tested the circuit, I found that manipulations made in the probe wiring deteriorated part of my ECU, thus c 'is or I'll ask for advice:
-I opportunity to change my ECU, is it possible to completely cancel the management of sensors and leave the engine running with the default programming of the ECU operation used when replacing exhaust steel not provided for mounting probes
-Purchase of ECU internet (MB gold prices to sell) even OCCAZ, reading my ECU and the new REPROG
on ebay or another I found ECU 55 ml same year as mine, but the killer question, is he going to fully recognize my mL, I do not want to distort my city and my contacts key will she walk
Thank you in advance for the interest you could bring to my problem
Stephan
