Air Conditioning Intermittent
Hello,
I have a 2000 ML320. The a/c has become intermittent. When the outside temperature is cooler, the a/c works fine. When the outside temperature starts to get hot, the a/c will blow warm air. I have also noticed when the a/c is on the car seem to run rough. Runs just fine when the a/c is off (or not working).
Any suggestion.
Thanks!
Any suggestion.
Thanks!
miguel446 (09-06-2016)
What is probably happening is the system is low on refrigerant the the compressor clutch is cycling on and off.
When the problem occurs, open the hood and look at the compressor clutch. If it spins, then stops and then spins, etc., you are low on refrigerant.
C.P. (04-15-2016)
Intermittent Air Conditioning
I also have a similar issue. I have a 1999 ML320. Two years ago, I had to get the compressor replaced ($$$$) and the evaporator valve overhauled. I live in a hot summer climate and when the temperature gets above 90, the A/C blows hot and cold air. What I mean by this is when driving on the highway or the engine is running at a driving speed, the AC works fine. When I am in traffic or at a light, it blows continually warmer. I can hear and feel the compressor cycle in and out. I have the equipment to check the freon as I suspected this also was the problem but it is ok. Any idea what the issue is? I suspect there may be some pressure switch that is not operating correctly but don't know enough to verify this.
When this happens it means that your fan clutch is faulty and not spinning fast enough. It must be replaced.
Maj. Dundee, Many thanks. This is the second time you were right on for me with your problem diagnosis. I bought an OEM clutch on the Internet, the special spanner wrench and 36mm wrench and still have 3+ "C notes" in my pocket. I changed it literally in minutes. The most time consuming thing was cleaning the fan.
2005 ML350
Maj. Dundee, sorry to reopen this thread as I was reading a lot of the thread on here. I'm still confuse as I'm not sure how the compressor works. But when i look at the engine there is only one belt driving all the pulleys. So looking at the compressor I can't tell if it's working or not. I don't know what you mean the "clutch is cycling on and off". Can you point to a video demonstrating how it works?
Many thanks,
Many thanks,
![](https://cimg5.ibsrv.net/gimg/www.mbworld.org-vbulletin/1091x703/aaaaaaaaab_7d14e66095bcf51da4431bf99b9281349a15f9f0.jpg)
Your compressor does not have a clutch which turns on and off. Everything is activated inside the compressor. Describe you problem.
Also PLEASE UPDATE YOU PROFILE in USER CP to include the year and where you live.
2005 ML350
Thanks for quick response!
My two front fans are not kicking in when I turn on AC. While AC is on the engine
seem to be louder while idling and while driving the it doesn't accelerate as fast while AC is off like many have stated.
thanks
thanks
The aux. fans will only come on when certain criteria has been met.
The loud sound is probably coming from the main cooling fan because it is running at full speed. If that is the case, there is something wrong with the cooling system or there is a mechanical problem with the eng. & the ECM is reducing performance to protect the eng.
This part I do not understand............. the it doesn't accelerate as fast while AC is off like many have stated.
2005 ML350
Thank you for the explanation.
Do you have an idea why the fan clutch has to work more than needed.
During summer months my temp gauge would go up to almost 100c while idling! The two front fans would not come on.
I'm very concern, because before it would always stay at 80c. While driving it goes back down to about 90c in hot weather.
In the winter, like now it would stay a tad above 80c constantly. But when idle it would fluctuate up to 90c. Still the aux fans does not come on.
Im a DIY guy that can follow instructions not an expert if you know what I mean. If you could help provide me instruction on how I go about verify the PDF instructions you provided, that would be awesome.
Sorry, for not making it clear. The engine does not accelerate as much when AC is on. But when AC is off, it's a little better.
BTW, I've replace the thermostat, water pump, expansion tank, fan clutch, and the coolant circulation pump last year.
thanks again!
thanks again!
![](https://cimg4.ibsrv.net/gimg/www.mbworld.org-vbulletin/993x457/2018_01_11_054530_f6289ad70aa5957cd87796a72f8fc7877444ad67.jpg)
The fan clutch runs at a higher speed because the clutch detects that the temp. is rising and therefore makes it run at a higher speed.
The aux. fans will not come on until the coolant temp. has reached 105°C on your temp gauge. According to you, the temp. is only at 100°C, so the aux. fans will not come. Do you understand?
2005 ML350
Thanks, I understand why the fans are not coming on.
Now back to the ac compressor. How do I know it's working properly? Last night, i tested the AC after driving home from work. When AC is on I can hear a slight change in noise near the AC compressor but not sure what it was. Thought it was the bearing on the pulley that has gone bad, but that sound only last for couple of seconds. So I decided to remove the serpentine belt and check to see if any of the pulleys are bad. All of them spins freely without any noise and resistant except the AC compressor. It has quite a resistance and kind if stiff for it to rotate. Is this normal or should it suppose to spin freely? Sorry for all the dummy questions. Thanks
Contrary to popular belief all pulleys, except the A/C compressor, should have resistance when spinning them. The A/C pulley should be hard to spin.
Copy and paste these questions and type answers along side each one.
1. how long ago did this problem start?
2. did you replace all those parts to correct this problem?
3. do you own a scanner?
4. since the problem started, has the CEL come on?
5. what color coolant is in the expansion tank?
6. when you replaced the expansion tank, did you also get a new cap?
2005 ML350
Thank you for confirming the a/c compressor state.
This noise,i just happen to hear it recently because i started to check why i keep hearing squeaking sound when backing off from the garage in the early morning. It only happens in the morning and afterwards it's all ok. Moving forward, there is no sound. I popped the rear brakes out to see if there are anything loose but everything was intact. I will check front brakes tonight and report back.
No, i replace all those parts due to temperature gauge keep fluctuating between 85c-100c over a year ago and it still does it till now. That is when i brought to the dealer and they say it's normal, but I don't trust them. I told them when I bought this car new it was always at 80c constantly no matter what what temperature outside was. But still the problem been like this for over a year. Still bugs me and I need help looking into this problem and don't want to drive my car in the summer in 90-100c weather.
No, just ordered one and it will arrive in couple of days.
No, CEL does not come on.
Originally it was yellow, but the dealer sold me the MB blue color. After I've change it, I started to read further on the forum and found that I could of use Zerex G-05. But it's too late. Didn't want to switch it back.
Yes, I replace both expansion tank and a new cap as well.
5-6 months ago, I notice my car didn't have any cold Air when AC was on. After reading thru the forum, i went and bought a can of refrigerant and fill it up. I think i used up the can, but the air was cooler and I was happy but not as cold as before. I also hear some clicking noise inside the center console when turning it on then, but it seem to dissipate. Anyways, i think the engine is making loud noise due to cooling system as well, but unable to diagnose it. Any help is much appreciated.
![](https://cimg5.ibsrv.net/gimg/www.mbworld.org-vbulletin/1222x468/2018_01_11_081020_8ac9915c11b14e923e387ee3fb25fc19d0fe7368.jpg)
![](https://cimg6.ibsrv.net/gimg/www.mbworld.org-vbulletin/314x234/coolant_circulation_pump_loc_5d692b5a143b9b37acab43dc206376fd9f33d11f.jpg)
You seem to have two issues. The first is the A/C not working and with the last para. you typed about the clicking sound in the console means that the Blend Door Actuator Motor must be replaced. I will supply instructions for the blend motor.
But the second and more important issue is the engine performance and the temp. rising to 100°.
1. while the eng. is idling and at 100°, is there bubbling in the expansion tank?
2. while the eng. is idling and at 100°, check the hose at the expansion tank, pictured below, and see that every portion of the hose is hot to the same degree. Also check the hoses before and after at the Coolant Cir. Pump.
3. Depending on the answers above, it might be a good idea to change the Coolant Temp. Sensor.
4. and you still didn't answer this question.............. the it doesn't accelerate as fast while AC is off like many have stated. What does like many have said mean?
2005 ML350
Thanks Maj Dundee
Report: I check my front brakes last night. Everything seems to be intact. Nothing loose.
1. I will purchase tools and parts to replace the Blend Door Actuator Motor as you suggested. The keys to remove the radio and the wedges to remove the bezel. Are they only available at the dealer or available online. I tried searching online but couldn't come across. Maybe someone can help attach a link to the tools needed.
2. I will test and record item 1 & 2 above and report back to you
I forgot to mention that I've also replace the Coolant Temp Sensor while replace the water pump last year.
3. "the it doesn't accelerate as fast while AC is off like many have stated"
I have answer this on post #13. Sorry, for not making it clear. The engine does not accelerate as much when AC is on. But when AC is off, it's a little better and less noise.
Hold on. I did not say to go ahead and replace the Blend Door. There are things that you have to check before replacing it.
What does like many have stated mean?
2005 ML350
"many have stated" Means I have read the forum and some people mentioned that with AC on the engine has less power to accelerate while AC is off the engine has more power to accelerate. That is all.
ok, I will wait on replacing the blend motor.
2005 ML350
Hi Maj. Dundee,
Report on the temperature readings. Please see video below. Sorry for bad lighting and hand coordination.
https://photos.app.*******/WcxmFE7BDE8oGNZY2
This video show the temp gauge over 90c but not to 100c at Idle cause outside temp is cold . If in hot summer temp gauge should read 100c easily.
https://photos.app.*******/vSOmi3OOw1PVe55G3
Can you also comment on axle video below see if this axle is bad. It has clicking sound but stiff.
https://photos.app.*******/i3j0dyTikvbgAI952
Thank you
Thank you
None of these photo links will open.
You still haven't given the results of the question on the hoses and to be very honest with you, I'm getting tired of double checking on you to make sure you answer my questions.
2005 ML350
Not sure why it's removing the characters in between and change to ***** in between the links
Sorry, can someone show how do I manage it? Can I send you or email you the link directly?
