Low Coolant Light but fluid is at the level
Old Jul 22, 2016 | 10:23 PM
jayxgomez's Avatar
ML500 2002
I have a 2002 ML500 the Low coolant light has come on. It drives fine when on highways but then will start to heat up above normal operation. The fan kicks works but I'm not sure if it kicks into a high speed. Any suggestions ?
Old Jul 22, 2016 | 11:29 PM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
When it is fine with hwy. speeds but not at idle, it is the Fan Clutch that must be replaced.
Old Jul 22, 2016 | 11:46 PM
jayxgomez's Avatar
ML500 2002
Would that cause the low coolant light to come on as well ?
Old Jul 23, 2016 | 06:14 AM
Yes it could trigger the light, but do this easy test to find out if the Fan Clutch is operating correctly.
Attached Thumbnails Low Coolant Light but fluid is at the level-fan-clutch-testing.jpg
File Type: pdf
Old Jul 23, 2016 | 07:53 AM
jayxgomez's Avatar
ML500 2002
Thanks I'll try that tomorrow.
Old Jul 23, 2016 | 08:02 AM
Please UPDATE YOUR PROFILE in USER CP to include the year and where you live.
Attached Thumbnails Low Coolant Light but fluid is at the level-aaaaaaaaab.jpg
