ML430
Old Feb 11, 2017 | 04:13 PM
bsandyk44's Avatar
2017 GLE 350
ML430
I have a fuel gauge issue with my 2001 ML 430. My fuel pump seems ok. Is there a quick check with replacement or resetting the fuse?
Old Feb 11, 2017 | 11:55 PM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Here is the reset procedure.
File Type: pdf
Old Feb 12, 2017 | 01:06 PM
bsandyk44's Avatar
2017 GLE 350
ML 430
Thank you so much! However, I just filled up and set the odometer to 0. I won't know when it will be 1/2 full so will this work if I go below 1/2 full or should I try to be more accurate?
Old Feb 13, 2017 | 04:56 AM
Then go by the mileage on the trip odometer.
Old Feb 13, 2017 | 11:28 AM
bsandyk44's Avatar
2017 GLE 350
Again, thanks much.
Old Apr 27, 2017 | 10:39 AM
bsandyk44's Avatar
2017 GLE 350
Hello now I have an issue with my 2001 ML 420. I can't lock or unlock the car using the key fob. I replaced the batteries, is there something else I can do?
Old Apr 27, 2017 | 09:08 PM
New problem requires a new thread.
