GPS problem
Old Apr 6, 2004 | 07:44 AM
panej's Avatar
ML430 ML320 300DT
Question GPS problem
I have a 2000 ML430 with about 71000 miles. The navigation system was working flawlessly until the past 3 months. It started intermittently with the map being off course (showing wrong location) and was only happening 10 percent of the time, then increased to the present point of not ever correcting the location. I also noticed that in the GPS Information, it does not see any satelites at all.
Any ideas?
Old Apr 6, 2004 | 12:05 PM
UncAl's Avatar
1998 ML-320
You might try
to remove the GPS antenna to check for rust/corrosion. If the contacts appear OK, the antenna may be bad.
Good Luck!
Old Apr 6, 2004 | 11:51 PM
pointman's Avatar
a car that can't do the throttle reset.
i agree with UncAl, but i have the same issue and i am taking it to the dealer on monday. ill let you know what they say.
Old Apr 7, 2004 | 07:30 PM
Sandy's Avatar
2002 ML500, 2000 CLK320
I had the same problem and it took 2 years to solve! The unit was replaced twice. The antenna was replaced once. It turned out to be rust in the middle of the antenne wire from the antenne to the unit. In other words, replacing the antenna did not work; but they had to replace the whole cable.
Good luck - this drove me nuts!
Old Apr 8, 2004 | 08:34 PM
panej's Avatar
ML430 ML320 300DT
Thumbs up
Got it fixed at the dealership (Mercedes of Devon, Devon, PA):
New antenna, $277.00
Labor, $255.00
Diagnostics, $135.00
Now it is an expensive GPS
Old Apr 19, 2004 | 01:15 PM
pointman's Avatar
just had my antenna changed and new mcs put in (number 3)... still off. this is making me nuts.
Old Apr 20, 2004 | 11:28 AM
Sandy's Avatar
Get them to replace the cable from the antenna to the unit. This is EXACTLY what hapeened to me. Took 2.5 years to fix it!
When I first got the car, it would get lost 5% of the time. Over time, it got to the point when it would fail 70% of the time.
The pointer icon would float off course. It was like it was drifting out. It would then lock in on another road, then recalculate the course - very annoying. Sometimes the map would spin around and around - even when stopped at a light. Nothing would solve it (reboot etc). The nav unit was replaced twice.
I would persist for hours. The next day - it might be fine....but not for long.
I figured out that it consitantly happened one day AFTER it rained, or if I powerwashed the car. It happened more in winter than summer (I wash the car more in the winter).
This led me to believe that it was a leaky antenna housing. They relaced it, but it was still broken.
I took a movie of it, and send it to MB Canada. When they looked at it, they were perplexed. We got to the point where a refund (after almost 3 years) was about to come about. Then I asked them if they actually replaced the cable. After some research, they realized that when you replace the antenna, the cable to the unit is not replaced. We ordered this part. When they removed the antenna cable, they say they saw some rust on it a little ways into the car. There must have been some sort of leak - hence the issue got worse a few days after washing the car.
It's been working for 4 months now.
Every so often it loses track, but comes back after a few seconds. I figure this is normal.
Good luck.
Old Apr 20, 2004 | 12:00 PM
kostas's Avatar
2008 BMW 335xi Coupe
mine was having the same exact problems for about a year.. then they finally went ahead and replaced my antenna and it has been working fine so far.. its only been a month and i have only used it twice.. if it happens again.. i am gonna go there and tell them to give me my money back for the $500 antenna they made me pay for
Old Apr 20, 2004 | 01:39 PM
pointman's Avatar
thanks sandy...ill definitely let them know...but they are pretty stubborn and dont want to hear anything.
Old Apr 22, 2004 | 12:47 PM
Sandy's Avatar
That's too bad. I must say (and give a plug), that Ogilvie Motors, where I bring it, maintained total ownership of the probem for the entire time - they just didn't know what to do anymore. But, thoughout, they were fantastic.
Old Mar 17, 2007 | 09:56 AM
ljmiller's Avatar
Can anyone tell me how to change the GPS antenna on a 2001 ML430? Ever since the battery in the vehicle was changed, the nav shows me several hundred miles away from where I am actually located and it won't pick up any satellites.
