Check engine light
Old Apr 9, 2004 | 09:16 PM
VTBenZO's Avatar
ML320
Check engine light
Question,
I have a 2000 ml320 (45k), the check engine light just popped up, any ideas why? can I still drive it, or would I cause a harm if I do?
Thank you
Old Apr 9, 2004 | 10:00 PM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Yes, if it seems to run reasonably well drive it but have the dealer check the computer to see exactly which component needs attention. Its most likely one of the emmission control sensors such as one of the o2 sensors or the MAF sensor. But, get it fixed as long term operation could possibly cause some damage
Old Apr 10, 2004 | 12:42 PM
pointman's Avatar
a car that can't do the throttle reset.
if it drives fine...ou can dirve it. if there is a real issue, the car will let you know. the problem could be something emissions systems related, or as easy as a loose fuel cap. try tightening the fuel cap til you hear at least 3 clicks...then drive around a while and it might go away.
Old Apr 10, 2004 | 07:43 PM
kostas's Avatar
2008 BMW 335xi Coupe
not a big deal.. mine just came on as well.. i'm still gonna drive it around tho.. i wont have time to get it checked out until towards the end of May =\
Old Apr 15, 2004 | 05:14 PM
ML320AMG's Avatar
1998 ML320 + 1985 AE86
If you are in So Cal. I can scan it fo you with my OBDII reader to give you the peace of mind. PM me you need it
denis
Old Apr 21, 2004 | 03:07 PM
wml350's Avatar
E350---2007
Did you recently fill up your gas tank? If so check to make sure the cap in properly tightened.
