Immobilizer issues...
Old Apr 10, 2017 | 09:22 AM
Laura Nation's Avatar
2003 Mercedes Benz ML 350
Recently purchased a 2003 Mercedes Benz ML350. While driving it died. Received a Start Error Message. Looked it up in the owners manual. Immobilizer (anti theft device) issue. Without taking this vehicle to a Benz shop, is there any way this can be reset? I have researched and found several "fixes" online, but none of them have worked. Thank you....
Old Apr 11, 2017 | 06:56 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
The immobilizer is only necessary for recognizing the key and starting the truck. After that it plays no part in keeping the engine running.
Try and start the truck, all the time watching the Tachometer Gauge and see if it moves slightly upwards and bounces.
If it doesn't your Crankshaft Pos. Sensor is faulty.
If it does then it could be a fuel issue or a few other things. Codes must be read.
Old Apr 11, 2017 | 02:54 PM
Thank you Maj. Dundee....the Crankshaft Sensor is exactly what our mechanic said! He is currently installing and programming a new one. Certainly appreciate your knowledge and taking the time to reply in such a professional manner.
Old Apr 12, 2017 | 07:19 AM
You are quite welcome.
