2006 ML350
Old Jun 10, 2017 | 07:31 AM
mike bingham's Avatar
2006 ml 350
2006 ML350
Hello all..appreciate any help and thank you!!
just removed intake manifold from the m272 and it is very ugly. got new one on order. two questions-
1. there is rubber hose mounted to top of the transmission housing and appears to connect to driver side of the trans hosing. where does this S curve hose connect?
2. on front of intake manifold there are two vacuum lines. I found one running to the module below the air pump but no idea about the other one?
Old Jun 10, 2017 | 07:47 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
You are on the wrong forum.
http://www.benzworld.org/forums/w164-m-class/
