window switch or motor/regulator
Old Jun 22, 2017 | 10:42 PM
burlutskiy's Avatar
ML320 2001
Question window switch or motor/regulator
Hi,
The widow on driver side stopped working. It didn't stop working suddenly, it was like not closing all the way up and you had to pull on switch several times, however it went down w/o any issues. So one day it just stopped working at all, it basically went all the way down. I though it is a switch I replaced whole the central widow switch panel, but it didn't help, more over the left rear window stopped working... ... any ideas, thanks in advance?
Old Jun 23, 2017 | 08:17 PM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Please UPDATE YOUR PROFILE in USER CP to include where you live.
Attached Thumbnails window switch or motor/regulator-aaaaaaaaab.jpg
Old Jun 23, 2017 | 08:24 PM
Did the left rear window stop working after you replaced the switch pack?
Where did you buy the switch pack?
Do the rear windows operate using the rear window switches?
Old Jun 23, 2017 | 08:46 PM
burlutskiy's Avatar
ML320 2001
I am in Stamford, CT
I bought the switch board in Autozone, it was $170!, realized later that I could've bought it on ebay for $30.
The right rear window (srry it was right rear window no left) stopped working, when I was plugging and unplugging the cables from the old board, now I think I might have short circuited the board with screwdriver while the cables were plugged , so it might affected the regulator as well, however I don't have electric scheme with me. Not really sure what happened.
Also there was a some kind of glitch when I was plugging new board, the window rose up for 2-3 inches, and stuck there in that possition. Up/down not working driver seat and right rear.
I double checked that I connected the cables the right way, it basically not possible to plug the other side cable.
Old Jun 23, 2017 | 09:08 PM
Check fuse #30.
Old Jun 23, 2017 | 09:23 PM
burlutskiy's Avatar
ML320 2001
Thanks!!, it was F29 fuse, silly me I checked K16-K18 on this board yesterday, i thought they are the fuses and relay all together.
Old Jun 24, 2017 | 05:10 AM
Is everything working now?
Old Apr 6, 2022 | 03:24 PM
rossny's Avatar
ML 320 CDI 2008 JTNB11HK3J3024970
ML320 08 FD Window Stuck Down
Hi, Powered down the FD window and will not power up. No motion or noises at all when switching. FD Switch is a little loose/funky since I got it, all other switches are still working. Anyone know where the fuse(s) are for the drivers power window? I have looked at lists of fuses and didn't see it listed, must be me. Thanks for reading. W164 2008 ML320
Old Apr 6, 2022 | 03:29 PM
rossny's Avatar
a
Old Apr 8, 2022 | 07:36 AM
Rossny, You are on the wrong forum.
https://mbworld.org/forums/m-class-w164-72/
Old Jul 10, 2022 | 02:20 PM
SBundlez's Avatar
2011 E350 4matic
Did you solve this?
I plugged my switches back in today and forgot my battery was still connected. Saw a spark and now none of my windows work. With no clue what the issues is. could it be a relay? I checked all the fuses. aIf so where is the relay?
05ml350
Old Jul 10, 2022 | 02:41 PM
SBundlez's Avatar
2011 E350 4matic
Originally Posted by SBundlez
Did you solve this?
05ml350
Correction, after checking I have no power windows, seats, or mirrors.
