Transmission problem. 400cdi w163
Old Jul 7, 2017 | 07:23 AM
Ákos Fodor's Avatar
w163
I have W163 400cdi. I used to tow. While I drive 100km the transmission overheat and won't change gears. First time use 1,2,3,4 gear after 1,2,3. My fuel economy is catastrophic. What can I do?
Old Jul 7, 2017 | 12:21 PM
Ákos Fodor's Avatar
w163
Trailer with car. About 800-1200kg. 150 miles maximum
Old Jul 8, 2017 | 01:55 AM
Ákos Fodor's Avatar
w163
3.5ton
Old Jul 8, 2017 | 06:32 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
How did you know that the trans. overheated?
If you are going by the temp. gauge, then it is probably the the elec. cooling fan in front of the radiator.
Old Jul 8, 2017 | 07:45 AM
Ákos Fodor's Avatar
w163
Everything is okay with the cooling fan
Old Jul 9, 2017 | 12:37 AM
Because the fan is spinning does not mean that everything is OK. It might not be spinning fast enough, especially under a load.
File Type: pdf
